<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can I reuse the same FusionAuth license key across dev, staging, and production?]]></title><description><![CDATA[<p dir="auto">I am migrating from FusionAuth Cloud to a self-hosted deployment. I have successfully set up a new cluster and imported the database from the managed environment.</p>
<p dir="auto">In the self-hosted FusionAuth instance, I see an option to add a license key. When I check my account portal at <a href="http://account.fusionauth.io" rel="nofollow ugc">account.fusionauth.io</a>, I see a primary license key.</p>
<li>Can I use this same license key in parallel across multiple environments (dev, staging, production)?</li>
<li>Will using the key in my self-hosted deployment impact or conflict with the existing managed FusionAuth setup?</li>
<p dir="auto">I want to ensure I don't accidentally disrupt the current managed environment while setting up the new self-hosted instances.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3358/can-i-reuse-the-same-fusionauth-license-key-across-dev-staging-and-production</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 17:39:04 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3358.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 12 Nov 2026 16:26:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can I reuse the same FusionAuth license key across dev, staging, and production? on Thu, 12 Nov 2026 16:26:39 GMT]]></title><description><![CDATA[<p dir="auto">Yes, you can use your FusionAuth licenses across multiple environments, but you should use the appropriate license type for each:</p>
<h2>License Structure</h2>
<p dir="auto">In your account portal at <a href="http://account.fusionauth.io" rel="nofollow ugc">account.fusionauth.io</a>, you should see <strong>two licenses</strong>:</p>
<li><strong>Production License</strong> — use this for your production environment only</li>
<li><strong>Non-Production License</strong> — use this for your dev and staging environments</li>
<h2>Best Practice</h2>
<li>Deploy the <strong>Non-Production license</strong> to your dev and staging instances</li>
<li>Deploy the <strong>Production license</strong> to your production instance</li>
<p dir="auto">Both licenses can be active simultaneously across different deployments without conflict. The license key itself is tied to your account and does not interfere with your managed FusionAuth Cloud setup when used in self-hosted deployments.</p>
<h2>Important Notes</h2>
<p dir="auto"><strong>The non-production license can be used across as many non-production environments as you need</strong> — dev, staging, QA, UAT, CI/CD, or even individual developer local instances. There's no limit on the number of instances using the non-production key.</p>
<p dir="auto"><strong>Do not use the production license on non-production environments</strong> — this would cause test logins to count toward your Monthly Active Users (MAU) and affect your billing.</p>
<p dir="auto"><strong>License costs are not based on the number of instances</strong> — whether you have 1, 2, or 100 instances, the license cost is related only to your plan tier and MAU count.</p>
<p dir="auto"><strong>Using self-hosted licenses won't affect your FusionAuth Cloud deployment</strong> — the licenses operate independently, so activating your license keys on self-hosted instances will not disrupt your existing managed environment.</p>
<li><a href="https://fusionauth.io/docs/concepts/plans-and-limits/licensing" rel="nofollow ugc">Licensing Documentation</a> — Overview of FusionAuth licensing concepts</li>
<li><a href="https://fusionauth.io/license-faq#i-have-a-paid-license-for-an-essential-plan-do-i-need-a-license-key-for-my-development-qa-uat-servers-to-access-the-essential-features" rel="nofollow ugc">License FAQ: Non-Production Licenses</a> — Details on using licenses for dev/QA/UAT servers</li>
<li><a href="https://fusionauth.io/license-faq#if-i-have-a-licensed-plan-does-it-matter-how-many-deployments-a-license-is-installed-on-does-the-license-cost-change-based-on-whether-i-have-1-2-or-100-instances" rel="nofollow ugc">License FAQ: Multiple Deployments</a> — How license costs work with multiple instances</li>
<li><a href="https://fusionauth.io/docs/cloud/account/#portal-areas" rel="nofollow ugc">Account Portal Documentation</a> — Where to find your license keys</li>
<li><a href="https://fusionauth.io/docs/cloud/cloud-vs-self-hosted" rel="nofollow ugc">Cloud vs Self-Hosted</a> — Comparison of hosting options</li>
]]></description><link>https://fusionauth.io/community/forum/post/9056</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/9056</guid><dc:creator><![CDATA[FASupportBot]]></dc:creator><pubDate>Thu, 12 Nov 2026 16:26:39 GMT</pubDate></item></channel></rss>
