<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can you use FusionAuth with GraphQL?]]></title><description><![CDATA[<p dir="auto">I'd like to use the FusionAuth APIs with GraphQL.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/337/can-you-use-fusionauth-with-graphql</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 10:55:44 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/337.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 26 Aug 2020 15:43:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can you use FusionAuth with GraphQL? on Fri, 28 Aug 2020 16:51:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/221">@fusionauth_user</a>, are you using Klemen's schema or did you create your own?</p>
]]></description><link>https://fusionauth.io/community/forum/post/1013</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1013</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 28 Aug 2020 16:51:49 GMT</pubDate></item><item><title><![CDATA[Reply to Can you use FusionAuth with GraphQL? on Fri, 28 Aug 2020 13:12:55 GMT]]></title><description><![CDATA[<p dir="auto">Im using FA with my graphql api (hasura)</p>
]]></description><link>https://fusionauth.io/community/forum/post/1012</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1012</guid><dc:creator><![CDATA[fusionauth_user]]></dc:creator><pubDate>Fri, 28 Aug 2020 13:12:55 GMT</pubDate></item><item><title><![CDATA[Reply to Can you use FusionAuth with GraphQL? on Wed, 26 Aug 2020 15:45:26 GMT]]></title><description><![CDATA[<p dir="auto">There is no officially supported GraphQL implementation.</p>
<p dir="auto">However, a community member, <a href="https://github.com/klemens-morgenstern/" rel="nofollow ugc">Klemens Morgenstern</a>, has <a href="https://github.com/klemens-morgenstern/fusionauth-graphql" rel="nofollow ugc">created a schema</a> which may help you out. Take a look.</p>
]]></description><link>https://fusionauth.io/community/forum/post/976</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/976</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 26 Aug 2020 15:45:26 GMT</pubDate></item></channel></rss>
