<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to allow MFA deletion for users without verified email or phone?]]></title><description><![CDATA[<p dir="auto">I'm trying to allow a support user with the <code>mfa_deleter</code> role to remove MFA from users in the Admin UI. However, when attempting to delete MFA methods, they receive this error:</p>
<pre><code>cannot delete multi-factor method: no notification can be sent to this user. Ensure the user has a verified email address or phone number and that the correct templates are configured
<p dir="auto">Most of our users authenticate via SAML or social federated logins and do not have verified email addresses or phone numbers in FusionAuth.</p>
<p dir="auto">We don't need to send notification emails when MFA is removed — we just need the ability to remove MFA for these users. Is there a way to allow the <code>mfa_deleter</code> role to work without requiring verified contact information? I'd prefer not to give our support staff full admin access or build custom tooling.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3402/how-to-allow-mfa-deletion-for-users-without-verified-email-or-phone</link><generator>RSS for Node</generator><lastBuildDate>Sat, 21 Nov 2026 09:45:22 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3402.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 18 Nov 2026 18:29:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to allow MFA deletion for users without verified email or phone? on Wed, 18 Nov 2026 18:29:27 GMT]]></title><description><![CDATA[<p dir="auto">The <code>mfa_deleter</code> role has hard requirements that cannot be bypassed. To remove MFA methods using this role, the target user must be notifiable through at least one verified primary identity:</p>
<li><strong>Verified email</strong> + configured <code>tenant.emailConfiguration.adminTwoFactorMethodRemoveEmailTemplateId</code>, OR</li>
<li><strong>Verified phone number</strong> + configured <code>tenant.phoneConfiguration.adminTwoFactorMethodRemoveTemplateId</code></li>
<p dir="auto">These requirements are by design and cannot be adjusted. The <code>mfa_deleter</code> role includes these safeguards to reduce the risk of abuse—when an MFA method is removed via this role, FusionAuth sends a notification to the affected user, so they must have a verified communication channel available.</p>
<h2>Workarounds</h2>
<p dir="auto">You have two options to remove MFA for users without verified contact information:</p>
<h3>1. Use the Admin role</h3>
<p dir="auto">Users with the <strong>Admin</strong> role are not subject to these verification requirements and can remove MFA methods from any user in the Admin UI.</p>
<h3>2. Use the API</h3>
<p dir="auto">Remove MFA methods programmatically using the <a href="https://fusionauth.io/docs/apis/users/update" rel="nofollow ugc">Update a User API</a>:</p>
<pre><code class="language-http">PATCH /api/user/{userId}
Authorization: &lt;your-api-key&gt;
Content-Type: application/json
  "user": {
    "twoFactor": {
      "methods": []
<p dir="auto">This approach allows you to build a custom support tool that removes MFA without granting full admin privileges to support staff.</p>
<hr />
<li><a href="https://fusionauth.io/docs/concepts/types/roles#the-mfa_deleter-role" rel="nofollow ugc">The mfa_deleter Role</a> - Details on the <code>mfa_deleter</code> role's constraints and requirements</li>
<li><a href="https://fusionauth.io/docs/users/user-support-guide#remove-an-mfa-method-with-the-mfa_deleter-role" rel="nofollow ugc">User Support Guide: Remove an MFA Method</a> - Step-by-step instructions for using the <code>mfa_deleter</code> role</li>
<li><a href="https://fusionauth.io/docs/apis/users/update" rel="nofollow ugc">Update a User API</a> - API documentation for updating user properties, including MFA methods</li>
<li><a href="https://fusionauth.io/docs/concepts/types/roles#admin-ui-roles" rel="nofollow ugc">Admin Roles</a> - Complete list of FusionAuth Admin UI roles and their permissions</li>
<li><a href="https://fusionauth.io/docs/email/template-reference#admin-two-factor-authentication-method-removed" rel="nofollow ugc">Admin Two-Factor Authentication Method Removed Email Template</a> - Template used for notifications when admin removes MFA</li>
<li><a href="https://fusionauth.io/docs/messengers/template-reference#admin-two-factor-authentication-method-removed" rel="nofollow ugc">Admin Two-Factor Authentication Method Removed SMS Template</a> - SMS template for MFA removal notifications</li>
]]></description><link>https://fusionauth.io/community/forum/post/9145</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/9145</guid><dc:creator><![CDATA[FASupportBot]]></dc:creator><pubDate>Wed, 18 Nov 2026 18:29:27 GMT</pubDate></item></channel></rss>
