<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How do I migrate from FusionAuth Cloud to self-hosted for data residency?]]></title><description><![CDATA[<p dir="auto">We are currently using FusionAuth Cloud and need to migrate to a self-hosted deployment to meet data residency requirements. What is the recommended process for migrating our existing Cloud data to a self-hosted instance? We want to ensure minimal disruption and maintain all our existing user data, configurations, and settings during the migration.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3419/how-do-i-migrate-from-fusionauth-cloud-to-self-hosted-for-data-residency</link><generator>RSS for Node</generator><lastBuildDate>Sat, 21 Nov 2026 09:45:25 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3419.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 20 Nov 2026 19:35:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How do I migrate from FusionAuth Cloud to self-hosted for data residency? on Sat, 21 Nov 2026 03:59:23 GMT]]></title><description><![CDATA[<p dir="auto">To migrate from FusionAuth Cloud to self-hosted, follow this high-level process:</p>
<h2>Migration Steps</h2>
<li><strong>Request a database export</strong> from FusionAuth Support</li>
<li><strong>Match versions</strong>: Ensure your self-hosted FusionAuth and database versions match your current Cloud deployment before migrating</li>
<li><strong>Load the export</strong> into your PostgreSQL instance</li>
<li><strong>Configure your self-hosted instance</strong> to connect to that database</li>
<p dir="auto">Refer to the <a href="https://fusionauth.io/docs/migrate/hosting/from-cloud" rel="nofollow ugc">Migrate from FusionAuth Cloud</a> documentation for detailed steps.</p>
<h2>Licensing</h2>
<p dir="auto">Your plan includes both production and non-production license keys (available at <a href="http://account.fusionauth.io" rel="nofollow ugc">account.fusionauth.io</a>) :</p>
<li>Use the <strong>non-production key</strong> across dev and staging environments</li>
<li>Use the <strong>production key</strong> for your production environment</li>
<h2>Keeping Your Instance Updated</h2>
<li>Most updates require <strong>no downtime</strong></li>
<li>Releases with database schema changes are flagged in the <a href="https://fusionauth.io/docs/release-notes" rel="nofollow ugc">release notes</a> and need a brief pause during migration</li>
<li><strong>Always back up your database</strong> before updating</li>
<li>By default, FusionAuth won't apply database schema changes automatically in production. You can either:
<li>Enable <strong>silent mode</strong> for automatic migration on startup, or</li>
<li>Run migration scripts manually before upgrading</li>
<li>See <a href="https://fusionauth.io/docs/update/database-migrations" rel="nofollow ugc">database migrations documentation</a> for more details</li>
<h2>Multi-node Deployment Updates</h2>
<p dir="auto">If running multiple FusionAuth nodes, you can update using:</p>
<li><strong>Rolling updates</strong>: Update nodes one at a time (<a href="https://fusionauth.io/docs/update/prod-instance#rolling-update" rel="nofollow ugc">details</a>)</li>
<li><strong>Blue-green deployment</strong>: Switch traffic to a fully updated set of nodes (<a href="https://fusionauth.io/docs/update/prod-instance#blue-green-deployment" rel="nofollow ugc">details</a>)</li>
<p dir="auto">Either approach limits downtime to the brief pause during database migration.</p>
<h2>Recommended Next Steps</h2>
<li>Contact FusionAuth Support to initiate the database export</li>
<li>Confirm your current FusionAuth and database versions</li>
<li>Set up and test dev and staging environments before migrating production</li>
<li>Review the <a href="https://fusionauth.io/docs/cloud/cloud-vs-self-hosted" rel="nofollow ugc">Cloud-hosted vs. self-hosted</a> comparison</li>
]]></description><link>https://fusionauth.io/community/forum/post/9179</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/9179</guid><dc:creator><![CDATA[FASupportBot]]></dc:creator><pubDate>Sat, 21 Nov 2026 03:59:23 GMT</pubDate></item></channel></rss>
