<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can user_support_manager role modify user email addresses in FusionAuth?]]></title><description><![CDATA[<p dir="auto">I need to grant users the ability to change other users' email addresses in FusionAuth, but I don't want to assign the full <code>user_manager</code> role. I've tried using the <code>user_support_manager</code> role, but it doesn't allow editing email addresses.</p>
<p dir="auto">Is there a role that allows email modification without granting full user management permissions? I assume the restriction exists because allowing email changes could enable account takeover (e.g., changing an admin's email to your own), but I'd like to understand the options available.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3420/can-user_support_manager-role-modify-user-email-addresses-in-fusionauth</link><generator>RSS for Node</generator><lastBuildDate>Sat, 21 Nov 2026 09:45:27 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3420.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 20 Nov 2026 20:52:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can user_support_manager role modify user email addresses in FusionAuth? on Fri, 20 Nov 2026 20:52:15 GMT]]></title><description><![CDATA[<p dir="auto">The <code>user_support_manager</code> role is intentionally restricted from modifying identity information that could be used for authentication, including email addresses and usernames. This is a security measure to prevent potential account takeover scenarios.</p>
<p dir="auto">According to the <a href="https://fusionauth.io/docs/concepts/types/roles" rel="nofollow ugc">FusionAuth role documentation</a>, the <code>user_support_manager</code> role allows editing users except for authentication-related identity information.</p>
<p dir="auto">If you need to grant the ability to change user email addresses, the minimum required role is <code>user_manager</code>. There is no built-in role between <code>user_support_manager</code> and <code>user_manager</code> that allows email modification while restricting other permissions.</p>
<p dir="auto">If you need more granular control over what operations are permitted, you should implement custom logic using the FusionAuth API. This approach allows you to:</p>
<li>Control exactly which fields can be modified</li>
<li>Implement your own authorization logic</li>
<li>Add additional security checks or approval workflows</li>
<p dir="auto">Using the API gives you full flexibility to define permission boundaries that match your specific security requirements.</p>
]]></description><link>https://fusionauth.io/community/forum/post/9181</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/9181</guid><dc:creator><![CDATA[FASupportBot]]></dc:creator><pubDate>Fri, 20 Nov 2026 20:52:15 GMT</pubDate></item></channel></rss>
