<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Invalid license error in self-hosted deployment - what URLs need to be accessible?]]></title><description><![CDATA[<p dir="auto">We are running a self-hosted FusionAuth deployment and encountering an invalid license error. What outbound connections does FusionAuth need to establish for license verification, and what could cause license validation to fail?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3423/invalid-license-error-in-self-hosted-deployment-what-urls-need-to-be-accessible</link><generator>RSS for Node</generator><lastBuildDate>Sun, 29 Nov 2026 03:24:54 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3423.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 23 Nov 2026 14:53:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Invalid license error in self-hosted deployment - what URLs need to be accessible? on Mon, 23 Nov 2026 14:53:35 GMT]]></title><description><![CDATA[<p dir="auto">For self-hosted FusionAuth deployments, the instance needs to communicate with the following URLs for license verification:</p>
<li><code>https://reactor.fusionauth.io</code></li>
<li><code>https://metrics.fusionauth.io</code></li>
<li><code>https://license.fusionauth.io</code></li>
<p dir="auto">If your deployment is behind a firewall, proxy, or in a restricted network environment, ensure these URLs are allowlisted for outbound HTTPS traffic. Blocking these endpoints will prevent FusionAuth from verifying its license and cause invalid license errors.</p>
<p dir="auto"><strong>Additional considerations:</strong></p>
<p dir="auto"><strong>Community plan:</strong> If you're using the free Community plan (no license), outbound network connectivity is not required and you can block these hostnames without affecting functionality.</p>
<p dir="auto"><strong>Proxy configuration:</strong> If your environment requires routing traffic through a proxy, you can configure FusionAuth to use an egress proxy by setting the <code>proxy.host</code>, <code>proxy.port</code>, <code>proxy.username</code>, and <code>proxy.password</code> configuration parameters.</p>
<p dir="auto"><strong>Air-gapped environments:</strong> If your instance has no internet access, you'll need a special air-gapped license and should explicitly block these hostnames in your network configuration to prevent connection attempts.</p>
<p dir="auto"><strong>Testing connectivity:</strong></p>
<p dir="auto">You can verify that your FusionAuth server can reach the license server by running:</p>
<pre><code class="language-bash">curl -vv https://license.fusionauth.io
<p dir="auto">If you continue to see license validation issues after confirming connectivity to these URLs, check your FusionAuth logs for specific error messages related to license communication failures. You can access logs through the FusionAuth Admin UI by navigating to <strong>System → Logs</strong> (available in version 1.16.0 and later), or by checking the log files directly on your server.</p>
<li><a href="https://fusionauth.io/docs/deploy/harden/network-hostnames" rel="nofollow ugc">Required Network Hostname Access</a> - Complete list of required hostnames for licensed instances</li>
<li><a href="https://fusionauth.io/docs/deploy/production/system-requirements#network-access" rel="nofollow ugc">System Requirements - Network Access</a> - Details on network requirements and proxy configuration</li>
<li><a href="https://fusionauth.io/docs/deploy/production/install/air-gapping" rel="nofollow ugc">Air-gapping FusionAuth</a> - Guide for running FusionAuth in environments without internet access</li>
<li><a href="https://fusionauth.io/docs/deploy/troubleshoot/troubleshooting#logs" rel="nofollow ugc">Troubleshooting Logs</a> - How to access and review FusionAuth logs for error messages</li>
]]></description><link>https://fusionauth.io/community/forum/post/9187</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/9187</guid><dc:creator><![CDATA[FASupportBot]]></dc:creator><pubDate>Mon, 23 Nov 2026 14:53:35 GMT</pubDate></item></channel></rss>
