<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[What functionality uses the tenant issuer, and can it be changed from a hostname to a URL?]]></title><description><![CDATA[<p dir="auto">The issuer on a tenant is configured as just a hostname (e.g. <code>acme.com</code>) instead of a full URL with a scheme (e.g. <code>https://acme.com</code>). An external identity provider rejected this configuration because it doesn't comply with the OIDC specification, which requires a URL.</p>
<p dir="auto">The FusionAuth UI appears to prepopulate new tenants with just <code>acme.com</code> (a bare hostname), and the documentation indicates the issuer must include a scheme. This misconfiguration has been in place for years.</p>
<li>What functionality in FusionAuth uses the tenant issuer configuration?</li>
<li>Is it just OAuth/OIDC authorization responses, or does it appear elsewhere?</li>
<li>What steps are needed to safely change the issuer from a hostname to a full URL?</li>
]]></description><link>https://fusionauth.io/community/forum/topic/3426/what-functionality-uses-the-tenant-issuer-and-can-it-be-changed-from-a-hostname-to-a-url</link><generator>RSS for Node</generator><lastBuildDate>Sun, 29 Nov 2026 03:22:55 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3426.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 24 Nov 2026 16:00:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to What functionality uses the tenant issuer, and can it be changed from a hostname to a URL? on Tue, 24 Nov 2026 16:00:13 GMT]]></title><description><![CDATA[<p dir="auto">The tenant issuer appears in <strong>three places</strong>, not just authorization responses:</p>
<p dir="auto"><strong>JWT <code>iss</code> claim</strong> — It's the issuer in every access token and ID token issued for the tenant. This is the biggest impact, because every API, gateway, or library that validates the <code>iss</code> claim is configured with the current value.</p>
<p dir="auto"><strong>OIDC discovery</strong> — It's the <code>issuer</code> value returned by <code>/.well-known/openid-configuration</code>. Spec-compliant clients and libraries expect an <code>https://</code> URL here, and the discovery URL must be based on it.</p>
<p dir="auto"><strong>OAuth authorization responses</strong> — As of FusionAuth 1.69.0, FusionAuth returns an <code>iss</code> parameter in Authorization Code and Implicit responses per RFC 9207. Clients that validate this parameter will reject a bare hostname.</p>
<h2>Steps to correct the issuer</h2>
<p dir="auto"><strong>Change the issuer</strong> under Tenants → Edit → General to <code>https://&lt;your-domain&gt;</code>.</p>
<p dir="auto"><strong>Regenerate signing keys</strong> — The issuer is tied to the generated signing keys. Per application, go to the JWT tab and select "Auto generate a new key on save" for both the access token and ID token keys. See <a href="https://fusionauth.io/community/forum/topic/2871/is-it-possible-to-change-the-tenant-issue-domain">this forum post</a> for more details.</p>
<p dir="auto"><strong>Review application OAuth URLs</strong> — Any application OAuth configuration that references the old issuer value must be updated manually. These are not updated automatically when the tenant issuer changes.</p>
<p dir="auto"><strong>Note:</strong> The prepopulated <code>acme.com</code> hostname in the new-tenant UI (without a scheme) is a known bug. Until it's fixed, manually set the issuer to a full URL when creating new tenants.</p>
]]></description><link>https://fusionauth.io/community/forum/post/9193</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/9193</guid><dc:creator><![CDATA[FASupportBot]]></dc:creator><pubDate>Tue, 24 Nov 2026 16:00:13 GMT</pubDate></item></channel></rss>
