<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Seeing &quot;A request to the search index has failed. This error is unexpected&quot; and I can no longer login with google]]></title><description><![CDATA[<p dir="auto">I'm having an issue with identity-provider/login, it all worked until recently, now i’m getting a 503 with the error - “A request to the search index has failed. This error is unexpected. Contact Support.” No other log entries.</p>
<p dir="auto">Search is running. I can log in via normal password route, this error just happens with the identity-provider/login through google.</p>
<p dir="auto">It’s replicable every time I try to login with google identity provider, it was working fine until recently. No changes to the system. I didn’t change config, i had to reboot my docker ec2 image (because another container caused a crash--not related), and restart all services, but that's all…no code changes for months.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/375/seeing-a-request-to-the-search-index-has-failed-this-error-is-unexpected-and-i-can-no-longer-login-with-google</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 03:19:21 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/375.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Sep 2020 01:57:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Seeing &quot;A request to the search index has failed. This error is unexpected&quot; and I can no longer login with google on Wed, 09 Sep 2020 01:57:55 GMT]]></title><description><![CDATA[<p dir="auto">Hmmm. Since you haven't made any changes and aren't seeing any other errors, can you try to reindex?</p>
<p dir="auto">Navigate to <code>system</code> and then <code>re-index</code> in the administrative user interface?</p>
<p dir="auto">That should solve the issue.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1093</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1093</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 09 Sep 2020 01:57:55 GMT</pubDate></item></channel></rss>
