<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[maximum pool size configuration]]></title><description><![CDATA[<p dir="auto">Is the database.maximum-pool-size property compatible with 1.18.7? or do i need to be running 1.19.x+</p>
]]></description><link>https://fusionauth.io/community/forum/topic/403/maximum-pool-size-configuration</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 22:13:31 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/403.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 17 Sep 2020 18:44:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to maximum pool size configuration on Thu, 17 Sep 2020 18:44:56 GMT]]></title><description><![CDATA[<p dir="auto">You can use the <code>database.maximum-pool-size</code> value in the <code>fusionauth.properties</code> file prior to 1.19.x ( it was just not documented) , but if you want to use the environment variable version is not available until 1.19.x.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1180</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1180</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 17 Sep 2020 18:44:56 GMT</pubDate></item></channel></rss>
