<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How do you assign a theme to an application?]]></title><description><![CDATA[<p dir="auto">How do you assign a theme to a FusionAuth application? I looked in the admin ui and the theme docs and api and didn't see a way to map between the two.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/42/how-do-you-assign-a-theme-to-an-application</link><generator>RSS for Node</generator><lastBuildDate>Mon, 05 Oct 2026 11:32:24 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/42.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 May 2020 16:20:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How do you assign a theme to an application? on Thu, 25 Nov 2021 03:17:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/114">@fred-fred</a></p>
<p dir="auto">Hiya,</p>
<p dir="auto">In addition to what <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/56">@maciej-wisniowski</a> suggested, if you have a paid license you can now have application specific themes (one theme per application; if no application theme is specified, it defaults to the tenant).</p>
<p dir="auto">You can see how that works in the sandbox environment (<a href="http://sandbox.fusionauth.io" rel="nofollow ugc">sandbox.fusionauth.io</a>). I believe that feature landed in 1.27.0.</p>
<p dir="auto">You can buy a <a href="https://fusionauth.io/pricing/" rel="nofollow ugc">licensed edition here</a>.</p>
]]></description><link>https://fusionauth.io/community/forum/post/3997</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3997</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 25 Nov 2021 03:17:42 GMT</pubDate></item><item><title><![CDATA[Reply to How do you assign a theme to an application? on Wed, 24 Nov 2021 21:14:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/114">@fred-fred</a> You can customize the templates (eg macro body in helpers.ftl) in your theme like this:</p>
<pre><code>[#if application?? &amp;&amp; application.name?? &amp;&amp; application.name == "MyApp1"]
       this is myapp 1 login screen
[#elseif application?? &amp;&amp; application.name?? &amp;&amp; application.name == "FusionAuth"]
       this is FusionAuth login screen
[#else]
       this is something else
[/#if]
]]></description><link>https://fusionauth.io/community/forum/post/3993</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3993</guid><dc:creator><![CDATA[maciej.wisniowski]]></dc:creator><pubDate>Wed, 24 Nov 2021 21:14:50 GMT</pubDate></item><item><title><![CDATA[Reply to How do you assign a theme to an application? on Tue, 23 Nov 2021 22:51:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> Is there any other way to assign a themed UI in the same tenant id if the client ids are different?</p>
<p dir="auto">For example, we have the same user base from two different companies in our FusionAuth (FA) tenant.</p>
<p dir="auto">Both companies can access the same applications that we host as defined in the applications section of FA.</p>
<p dir="auto">However, one of the companies has a specific application that they host, which we restrict only to them by the client id of the application.</p>
<p dir="auto">It would be nice to show a different logo on the oauth2/authorize screen when a specific clientId shows up in the querystring of oauth2/authorize</p>
<p dir="auto">Is this possible?</p>
]]></description><link>https://fusionauth.io/community/forum/post/3988</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3988</guid><dc:creator><![CDATA[fred.fred]]></dc:creator><pubDate>Tue, 23 Nov 2021 22:51:01 GMT</pubDate></item><item><title><![CDATA[Reply to How do you assign a theme to an application? on Fri, 01 May 2020 16:21:53 GMT]]></title><description><![CDATA[<p dir="auto">Themes are mapped to tenants. Per <a href="https://fusionauth.io/docs/v1/tech/apis/themes" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/apis/themes</a></p>
<p dir="auto">Themes are configured per Tenant.</p>
]]></description><link>https://fusionauth.io/community/forum/post/94</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/94</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 01 May 2020 16:21:53 GMT</pubDate></item></channel></rss>
