<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Login with Magic Link?]]></title><description><![CDATA[<p dir="auto">I am following the "Passwordless in less than 60 seconds" video. I don't have the  login choice "Magic Link". Why is this?</p>
<p dir="auto">I also notice that in the video the user is going to Edit Application home/settings/applications/edit. I don't have this choice on my Fusion Auth. Could this be a version issue? I am on 1.19.4</p>
]]></description><link>https://fusionauth.io/community/forum/topic/436/login-with-magic-link</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Nov 2026 04:37:51 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/436.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Sep 2020 19:30:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Login with Magic Link? on Mon, 19 Oct 2020 21:16:08 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">But if I put these in the application, won't this be a security problem?</p>
<p dir="auto">If you put them in a javascript app, yes. But if they are in the php application only, then it'll be like a database password. Not really a security issue.</p>
<p dir="auto">You could also inject them as an environment variable or pull from a secrets manager; however you manage your database credentials, I'd suggest doing the same with the client id/secret.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1482</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1482</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 19 Oct 2020 21:16:08 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Mon, 19 Oct 2020 12:49:49 GMT]]></title><description><![CDATA[<p dir="auto">OK Dan. I have gotten the email sent and I do show up at the redirect URL. Now I need to get the access token. To do this I need the $provider, which you can see depends on the $clientId and $clientSecret (see below). But if I put these in the application, won't this be a security problem?</p>
<p dir="auto">$provider = new \League\OAuth2\Client\Provider\GenericProvider([<br />
'clientId'                =&gt; $client_id,<br />
'clientSecret'            =&gt; $client_secret,<br />
'redirectUri'             =&gt; $redirect_uri,<br />
'urlAuthorize'            =&gt; $fa_url.'/oauth2/authorize',<br />
'urlAccessToken'          =&gt; $fa_url.'/oauth2/token',<br />
'urlResourceOwnerDetails' =&gt; $fa_url.'/oauth2/userinfo'<br />
]);</p>
<p dir="auto">So my question is how do I get an access token inside the redirect URL?</p>
]]></description><link>https://fusionauth.io/community/forum/post/1472</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1472</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Mon, 19 Oct 2020 12:49:49 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Thu, 08 Oct 2020 22:36:15 GMT]]></title><description><![CDATA[<p dir="auto">Sounds good <img src="https://fusionauth.io/community/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=rcgg4tg866g" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">If you want to verify it is working:</p>
<li>start up your php app</li>
<li>add a user in the admin screen</li>
<li>register the user for your application</li>
<li>go to the list of applications, click on the green magnifying glass next to your application and look for the 'login url'. copy that.</li>
<li>open an incognito window</li>
<li>paste the url</li>
<li>you should be prompted to login. use the username and password of the user you just added</li>
<li>you should end up at the redirect URL</li>
<p dir="auto">for what to do from there, I'd suggest looking at this code: <a href="https://github.com/FusionAuth/fusionauth-example-php-connector/blob/auth-with-oauth/oauth-callback.php#L24" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-example-php-connector/blob/auth-with-oauth/oauth-callback.php#L24</a> which gets a token.</p>
<p dir="auto">You could also start making API calls, as shown in this code: <a href="https://github.com/FusionAuth/fusionauth-example-php-webhook/blob/master/webhook.php#L36" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-example-php-webhook/blob/master/webhook.php#L36</a> (you won't want to make that call, but that's how you'd initialize a client and make calls to, say, update the user's data.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1418</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1418</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 08 Oct 2020 22:36:15 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Thu, 08 Oct 2020 19:07:12 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Are you asking for some free consulting <img src="https://fusionauth.io/community/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=rcgg4tg866g" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":slightly_smiling_face:" alt="🙂" /> ?</p>
<p dir="auto">No, I can play this "trial and error" game for months :). Seriously though, I am a little concerned that I couldn't enter the URL for quite a few days and then it started working. I just want to be sure that the authorized request origin URL is actually being used.  Is there some easy way to test that without using the API?<br />
Did I mention that I appreciate your help and the T-shirt too?</p>
]]></description><link>https://fusionauth.io/community/forum/post/1416</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1416</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Thu, 08 Oct 2020 19:07:12 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Thu, 08 Oct 2020 17:24:02 GMT]]></title><description><![CDATA[<p dir="auto">Heya,</p>
<p dir="auto">Are you asking for some free consulting <img src="https://fusionauth.io/community/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=rcgg4tg866g" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /> ?</p>
<p dir="auto">I think testing/writing each of these steps separately is a good idea. Step a should be pretty straightforward, step b doesn't involve fusionauth (I don't think, we do have a welcome email, but that happens when you add the user without any action). step c is your code + a fusionauth API call and step d is your code too.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1415</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1415</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 08 Oct 2020 17:24:02 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Wed, 07 Oct 2020 17:06:32 GMT]]></title><description><![CDATA[<p dir="auto">OK. Got it in there.<br />
<img src="/community/forum/assets/uploads/files/1602090245279-screenshot-from-2020-10-07-13-03-04.png" alt="Screenshot from 2020-10-07 13-03-04.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Now, how should I test that this is working OK? My initial plan was to a) add users via the API b) send login message via email c) have users complete login via link in email d) have user hot the Send button to submit the form.</p>
<p dir="auto">But now I think i should test step by step. What is next?</p>
]]></description><link>https://fusionauth.io/community/forum/post/1391</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1391</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Wed, 07 Oct 2020 17:06:32 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Wed, 07 Oct 2020 13:47:14 GMT]]></title><description><![CDATA[<p dir="auto">Glad to see you're figuring things out.</p>
<p dir="auto">https/http shouldn't be a problem. Is there a space at the beginning or end of your url?</p>
]]></description><link>https://fusionauth.io/community/forum/post/1383</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1383</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 07 Oct 2020 13:47:14 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Wed, 07 Oct 2020 00:06:08 GMT]]></title><description><![CDATA[<p dir="auto">Well I <em>almost</em> got it. Here is the screenshot. Notice the invalid URL? I do not have a an SSL Certificate for this laptop. Could this be the issue? <img src="/community/forum/assets/uploads/files/1602029163005-screenshot-from-2020-10-06-20-02-22.png" alt="Screenshot from 2020-10-06 20-02-22.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fusionauth.io/community/forum/post/1381</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1381</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Wed, 07 Oct 2020 00:06:08 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Tue, 06 Oct 2020 16:38:36 GMT]]></title><description><![CDATA[<p dir="auto">Notice that when I first login to the control panel (see attached), the Smart Link is not there. <img src="/community/forum/assets/uploads/files/1602002310285-screenshot-from-2020-10-06-12-37-07.png" alt="Screenshot from 2020-10-06 12-37-07.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fusionauth.io/community/forum/post/1376</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1376</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Tue, 06 Oct 2020 16:38:36 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Tue, 06 Oct 2020 15:15:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> said in <a href="/community/forum/post/1367">Login with Magic Link?</a>:</p>
<p dir="auto">You are an admin (you have the admin role in the FusionAuth app) so you should be able to add a redirect URI.</p>
<p dir="auto">But I am trying to use the Research Credit Toolkit application. I haven't tried it with the FusionAuth application yet. Anyway I am going to try to record a screen video. I use Screenshot which doesn't have that ability. Can you recommend an app to do the recording with?</p>
]]></description><link>https://fusionauth.io/community/forum/post/1375</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1375</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Tue, 06 Oct 2020 15:15:39 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Mon, 05 Oct 2020 20:08:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> said in <a href="/community/forum/post/1361">Login with Magic Link?</a>:</p>
<p dir="auto">You can't paste text into that input box, you have to type it. Are you trying to paste it in, perhaps?</p>
<p dir="auto">I was wrong, you can paste it in. You just can't paste in two or more urls.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1373</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1373</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 05 Oct 2020 20:08:37 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Sun, 04 Oct 2020 16:36:19 GMT]]></title><description><![CDATA[<p dir="auto">Hiya,</p>
<p dir="auto">Any chance you can record and upload a video of you trying to add the redirect URI? Everything looks solid from what I can see, so I'm a bit confused about what is happening.</p>
<p dir="auto">Glad you got the shirt! <code>cat /etc/passwd</code> is unix-speak for "show my all your passwords" <img src="https://fusionauth.io/community/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=rcgg4tg866g" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fusionauth.io/community/forum/post/1367</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1367</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Sun, 04 Oct 2020 16:36:19 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Sat, 03 Oct 2020 22:58:26 GMT]]></title><description><![CDATA[<p dir="auto">I am logged in as me and looking at the Users (attached) I am NOT an admin. Must I change that and how? BTW, my shirt came today. TY. <img src="/community/forum/assets/uploads/files/1601765835513-screenshot-from-2020-10-03-18-54-05.png" alt="Screenshot from 2020-10-03 18-54-05.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">BTW, what does cat  /etc/password mean?</p>
]]></description><link>https://fusionauth.io/community/forum/post/1366</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1366</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Sat, 03 Oct 2020 22:58:26 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Sat, 03 Oct 2020 02:22:22 GMT]]></title><description><![CDATA[<p dir="auto">You can't paste text into that input box, you have to type it. Are you trying to paste it in, perhaps?</p>
<p dir="auto">If not, then there's something I don't understand going on.</p>
<p dir="auto">Developing in docker shouldn't affect this.</p>
<p dir="auto">Are you logged in as the admin user?</p>
]]></description><link>https://fusionauth.io/community/forum/post/1361</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1361</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Sat, 03 Oct 2020 02:22:22 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Sat, 03 Oct 2020 01:49:45 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Dan. I watched the video. No, it will not take my redirect URL. Now, I don't have https on my laptop. Is that the issue? I am developing in a docker container on the laptop.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1358</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1358</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Sat, 03 Oct 2020 01:49:45 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Fri, 02 Oct 2020 22:49:39 GMT]]></title><description><![CDATA[<p dir="auto">Ah, that's a ux quirk. It isn't actually disabled, you should be able to add one or more urls to it.</p>
<p dir="auto">You can see how I add a redirect url here: <a href="https://youtu.be/trzY5otEgKM?t=254" rel="nofollow ugc">https://youtu.be/trzY5otEgKM?t=254</a></p>
<p dir="auto">Hope that helps.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1357</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1357</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 02 Oct 2020 22:49:39 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Fri, 02 Oct 2020 17:47:00 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/community/forum/assets/uploads/files/1601660764527-screenshot-from-2020-10-02-13-45-28.png" alt="Screenshot from 2020-10-02 13-45-28.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">see the very bottom? Authorized redirect URLs? I can't seem to change that since it is greyed out.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1354</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1354</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Fri, 02 Oct 2020 17:47:00 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Fri, 02 Oct 2020 13:04:29 GMT]]></title><description><![CDATA[<p dir="auto">Sorry, I was moving quick last night and misunderstood your comment. What do you mean you can't edit the redirect? Can you share a screenshot, please?</p>
]]></description><link>https://fusionauth.io/community/forum/post/1345</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1345</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 02 Oct 2020 13:04:29 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Fri, 02 Oct 2020 03:04:52 GMT]]></title><description><![CDATA[<p dir="auto">You need to add a redirect ("Applications" -&gt; your application -&gt; "OAuth" and then add a URL which can receive an authorization code and then retrieve an access token).</p>
]]></description><link>https://fusionauth.io/community/forum/post/1341</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1341</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 02 Oct 2020 03:04:52 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Fri, 02 Oct 2020 02:56:45 GMT]]></title><description><![CDATA[<p dir="auto">The oauth idp is : <a href="http://localhost:9011/oauth2/authorize?client_id=32688330-1630-4e0d-a4de-8ae45c3ca527&amp;response_type=code&amp;redirect_uri=" rel="nofollow ugc">http://localhost:9011/oauth2/authorize?client_id=32688330-1630-4e0d-a4de-8ae45c3ca527&amp;response_type=code&amp;redirect_uri=</a>{your redirect URI here}</p>
<p dir="auto">Notice that there is no redirect.! I am not able to fill in that field on Home/ Applications/Edit because it is greyed out.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1340</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1340</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Fri, 02 Oct 2020 02:56:45 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Wed, 30 Sep 2020 21:50:44 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/279">@richb201</a> ,</p>
<p dir="auto">The hosted pages are set up by default for you.</p>
<p dir="auto">So if I understand you correctly, are you saying that you have enabled passwordless for a given application but don't see the 'magic link' button on the login form?</p>
<p dir="auto">What is the "OAuth IdP login URL" value that you are trying to login with? (If you go to Applications and then click the green magnifying glass next to the application you are trying to set up, you can see this value.)</p>
<p dir="auto">Also, what is the value for "Passwordless login" from that same screen?</p>
]]></description><link>https://fusionauth.io/community/forum/post/1328</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1328</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 30 Sep 2020 21:50:44 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Wed, 30 Sep 2020 03:28:48 GMT]]></title><description><![CDATA[<p dir="auto">I am not using any login pages. Where would I set that up? The plan is to eventually send a passwordless email to a user, have them click the link which brings them to a form on my host.  But for now I am trying to get it to work with just the FusionAuth control panel.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1321</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1321</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Wed, 30 Sep 2020 03:28:48 GMT</pubDate></item><item><title><![CDATA[Reply to Login with Magic Link? on Wed, 30 Sep 2020 02:02:43 GMT]]></title><description><![CDATA[<p dir="auto">Sorry, when I say "hosted login pages" I mean the FusionAuth themed login pages.</p>
<p dir="auto">Are you using those?</p>
]]></description><link>https://fusionauth.io/community/forum/post/1320</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1320</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 30 Sep 2020 02:02:43 GMT</pubDate></item></channel></rss>
