<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Login Linking, Adding an Identity Provider to existing user]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">Is it possible to allow a user to add an Identity Provider to an existing login?  For example, they register with a username and password.  Then later, they decide they want to link there Google login to that user account.   Conversely, if they login with Google, later they want to add password login.</p>
<p dir="auto">I don't see anything obvious mentioned in the docs, is this possible?</p>
<p dir="auto">thanks,<br />
~ Paul</p>
]]></description><link>https://fusionauth.io/community/forum/topic/449/login-linking-adding-an-identity-provider-to-existing-user</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Jul 2026 17:22:06 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/449.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 03 Oct 2020 01:33:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Login Linking, Adding an Identity Provider to existing user on Sat, 03 Oct 2020 02:21:13 GMT]]></title><description><![CDATA[<p dir="auto">I think you are looking for this issue: <a href="https://github.com/FusionAuth/fusionauth-issues/issues/751" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/751</a></p>
<p dir="auto">This is open and therefore the functionality you are looking for isn't currently available.</p>
<p dir="auto">Please add your comment and/or your upvote to this issue. Here's our <a href="https://fusionauth.io/community/forum/topic/172/the-fusionauth-roadmap">current roadmap guidance</a>.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1360</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1360</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Sat, 03 Oct 2020 02:21:13 GMT</pubDate></item></channel></rss>
