<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SQL Server Support]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">Any chance of seeing SQL Server support for FusionAuth?  The .net community is in need of more good auth servers. I’ve been impressed with FusionAuth. Very easy to get up and going with docker.  Only think holding me back is not having SQL Server support.  The drivers are fairly good and cross platform now. My tech stack is already using SQL Server and I don’t want to have to host PostgreSQL as well.</p>
<p dir="auto">Thanks<br />
~ Paul</p>
]]></description><link>https://fusionauth.io/community/forum/topic/452/sql-server-support</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 23:43:47 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/452.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Oct 2020 03:40:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SQL Server Support on Wed, 07 Oct 2020 16:15:42 GMT]]></title><description><![CDATA[<p dir="auto">Another option is to use FusionAuth Cloud, then you do not need to be aware of the underlying data storage layer.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1389</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1389</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 07 Oct 2020 16:15:42 GMT</pubDate></item><item><title><![CDATA[Reply to SQL Server Support on Tue, 06 Oct 2020 17:35:08 GMT]]></title><description><![CDATA[<p dir="auto">Hi Paul,</p>
<p dir="auto">Thanks for the feedback, I'm glad you're finding FusionAuth useful. Definitely understand your position. I'm a big fan of consolidated tech stacks wherever possible.</p>
<p dir="auto">As of right now, we have no plans to support SQL Server. To remedy that, I can see three paths.</p>
<li>You could file a github issue detailing what you'd like to see (which version of SQL server, etc) in more detail. <a href="https://github.com/fusionauth/fusionauth-issues/issues" rel="nofollow ugc">https://github.com/fusionauth/fusionauth-issues/issues</a> This has the benefit of being free and relatively low investment. It has the downside of not actually guaranteeing that this feature/change becomes available. We rank feature requests based on community input as well as customer feedback.</li>
<li>You could take this on as a community project. We have other community projects (<a href="https://github.com/fusionauth/charts" rel="nofollow ugc">the helm charts</a>, for example). From googling, it looks like there are several mysql-&gt;sqlserver or postgresql-&gt;sql server translation projects. You can find the schema for FusionAuth <a href="https://fusionauth.io/direct-download" rel="nofollow ugc">here</a>. If I were doing this, I'd convert the schema, pop in the MS SQL Server JDBC driver to the tomcat webinfo directory and give it a go. This is obviously a heavy lift, but it's an option. If you documented that, I'd definitely read/share/promote that blog post.</li>
<li>You can engage us and see about a professional services agreement if you have budget. If you're interested in getting an estimate on this, please fill out a contact form: <a href="https://fusionauth.io/contact" rel="nofollow ugc">https://fusionauth.io/contact</a></li>
<p dir="auto">Here's our general roadmap guidance, which is probably worth a read: <a href="https://fusionauth.io/community/forum/topic/172/the-fusionauth-roadmap">https://fusionauth.io/community/forum/topic/172/the-fusionauth-roadmap</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/1377</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1377</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 06 Oct 2020 17:35:08 GMT</pubDate></item></channel></rss>
