<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[User Roles]]></title><description><![CDATA[<p dir="auto">Hi,<br />
when i login as admin in fusion auth then i am facing this issue :<br />
our account does not have permissions to access the FusionAuth Admin Interface. Your account has been registered but you have not been assigned any roles. Please contact your system administrator,</p>
<p dir="auto">How we fix that issue</p>
]]></description><link>https://fusionauth.io/community/forum/topic/518/user-roles</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 04:58:46 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/518.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Nov 2020 17:34:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to User Roles on Tue, 10 Nov 2020 23:55:15 GMT]]></title><description><![CDATA[<p dir="auto">Moved to q&amp;a section.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1665</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1665</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 10 Nov 2020 23:55:15 GMT</pubDate></item><item><title><![CDATA[Reply to User Roles on Wed, 04 Nov 2020 10:10:26 GMT]]></title><description><![CDATA[<p dir="auto">Did that solve your problem?</p>
]]></description><link>https://fusionauth.io/community/forum/post/1598</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1598</guid><dc:creator><![CDATA[eddielein]]></dc:creator><pubDate>Wed, 04 Nov 2020 10:10:26 GMT</pubDate></item><item><title><![CDATA[Reply to User Roles on Tue, 03 Nov 2020 21:08:47 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">If you have any other user account that has an admin role with the FusionAuth application then use this account to set the 'admin' role for your user (as the error message says).</p>
<p dir="auto">If there is no other useable admin account then seems something is screwed up (wondering how it is possible). You might try the API to update the registration for your user.</p>
<p dir="auto">If you don't have proper credentials for the API then I would try connecting directly to the database to find out if it is possible to add the role for the user there.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1594</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1594</guid><dc:creator><![CDATA[maciej.wisniowski]]></dc:creator><pubDate>Tue, 03 Nov 2020 21:08:47 GMT</pubDate></item></channel></rss>
