<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Custom themes for an application]]></title><description><![CDATA[<p dir="auto">Is there an ability to, or a roadmap item, to allow for custom themes on a an application instead of tenant basis?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/534/custom-themes-for-an-application</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 20:08:30 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/534.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Nov 2020 20:37:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Custom themes for an application on Tue, 03 May 2022 17:00:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> This was delivered in 1.27.0</p>
]]></description><link>https://fusionauth.io/community/forum/post/5085</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5085</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 03 May 2022 17:00:24 GMT</pubDate></item><item><title><![CDATA[Reply to Custom themes for an application on Fri, 06 Nov 2020 20:39:32 GMT]]></title><description><![CDATA[<p dir="auto">Yes, it's on the roadmap: <a href="https://github.com/FusionAuth/fusionauth-issues/issues/769" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/769</a></p>
<p dir="auto">This is something we want to solve. Currently the best solution is to use branch logic or stylesheets in the templates based upon the <code>client_id</code> which will be unique for each application.</p>
<p dir="auto">Another alternative is to have separate tenants for each application (after all, you can have as many tenants as you want) but that may cause issues because the user accounts in different tenants will be disconnected.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1641</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1641</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 06 Nov 2020 20:39:32 GMT</pubDate></item></channel></rss>
