<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is there any easy way to save and restore settings to different environments?]]></title><description><![CDATA[<p dir="auto">The use case is that I have set up a local development instance of FusionAuth. I want to replicate it it along with a .env file on other developer's machines for easier development setup.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/55/is-there-any-easy-way-to-save-and-restore-settings-to-different-environments</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 19:04:52 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/55.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 06 May 2020 23:30:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is there any easy way to save and restore settings to different environments? on Wed, 06 May 2020 23:31:31 GMT]]></title><description><![CDATA[<p dir="auto">You could look at kickstart: <a href="https://fusionauth.io/docs/v1/tech/installation-guide/kickstart" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/installation-guide/kickstart</a></p>
<p dir="auto">This would be a good fit if the other devs fusionauth instances are going to be starting from scratch.</p>
<p dir="auto">Otherwise you might want to vote for <a href="https://github.com/FusionAuth/fusionauth-issues/issues/560" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/560</a> which talks about a different path forward (which is as of now unimplemented).</p>
]]></description><link>https://fusionauth.io/community/forum/post/121</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/121</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 06 May 2020 23:31:31 GMT</pubDate></item></channel></rss>
