<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can you access timeout settings (for password resets, for example) in the email templates?]]></title><description><![CDATA[<p dir="auto">Is it possible to access timeout settings for password reset and passwordless login tokens from an email template?</p>
<p dir="auto">It would be nice to show users when the token will expire.</p>
<p dir="auto">Since these are set in the tenant settings, it would be great if the templates use the those values.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/60/can-you-access-timeout-settings-for-password-resets-for-example-in-the-email-templates</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 19:03:18 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/60.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 May 2020 16:08:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can you access timeout settings (for password resets, for example) in the email templates? on Fri, 08 May 2020 16:24:15 GMT]]></title><description><![CDATA[<p dir="auto">See also <a href="https://github.com/FusionAuth/fusionauth-issues/issues/612" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/612</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/133</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/133</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 08 May 2020 16:24:15 GMT</pubDate></item><item><title><![CDATA[Reply to Can you access timeout settings (for password resets, for example) in the email templates? on Fri, 08 May 2020 16:10:30 GMT]]></title><description><![CDATA[<p dir="auto">Not currently.</p>
<p dir="auto">You’d have to hard code it and keep it in sync with the config, perhaps by writing a script that ran regularly to sync up email template with the tenant setting.</p>
<p dir="auto">Please feel free to open a <a href="https://github.com/fusionauth/fusionauth-issues/issues/" rel="nofollow ugc">GitHub issue</a> with this suggestion, however.</p>
]]></description><link>https://fusionauth.io/community/forum/post/132</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/132</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 08 May 2020 16:10:30 GMT</pubDate></item></channel></rss>
