<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Client library versions]]></title><description><![CDATA[<p dir="auto">I am upgraded FusionAuth, should I also upgrade any client libraries that I use?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/636/client-library-versions</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 14:47:23 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/636.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 07 Dec 2020 16:21:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Client library versions on Mon, 07 Dec 2020 16:22:40 GMT]]></title><description><![CDATA[<p dir="auto">Yes.</p>
<p dir="auto">To ensure compatibility, I would recommend keeping your client library in sync with the version of FusionAuth.</p>
<p dir="auto">For example, if you have 1.21.0 installed, that would mean ensuring you use the 1.21.0 version of the Python client.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1888</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1888</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 07 Dec 2020 16:22:40 GMT</pubDate></item></channel></rss>
