<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I want to get a refresh token after login, but can&#x27;t figure it out]]></title><description><![CDATA[<p dir="auto">I'm having trouble getting a refresh token. I've checked out the docs: <a href="https://fusionauth.io/docs/v1/tech/oauth/endpoints/#refresh-token-grant-request" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/oauth/endpoints/#refresh-token-grant-request</a> but can't figure it out.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/637/i-want-to-get-a-refresh-token-after-login-but-can-t-figure-it-out</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 08:58:03 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/637.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 07 Dec 2020 16:31:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I want to get a refresh token after login, but can&#x27;t figure it out on Thu, 10 Dec 2020 15:41:05 GMT]]></title><description><![CDATA[<p dir="auto">This is a common issue, as there are a couple of prerequisite settings that you need to configure in order to get refresh tokens. When you are trying to get a refresh token and not seeing it, you should double check the following items:</p>
<li>you are passing a value of <code>offline_access</code> whenever a <code>scope</code> parameter is present.</li>
<li>you have configured the application to generate refresh tokens
<li>if you are using OAuth, in the UI, it is in the <code>OAuth</code> tab; the field is <code>Generate Refresh Tokens</code></li>
<li>if you are using the Login API, it is in the Security tab under <code>Login API Settings</code>; the field is <code>Generate Refresh Tokens</code>.</li>
<li>you are passing the <code>client_id</code> to the refresh grant request. This is required unless you are passing the <code>Authorization</code> header (which has the <code>client_id</code> in it).</li>
<li>the user is registered to the application for which you are issuing a refresh token.</li>
]]></description><link>https://fusionauth.io/community/forum/post/1890</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1890</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 10 Dec 2020 15:41:05 GMT</pubDate></item></channel></rss>
