<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can we increase timeout of the login request?]]></title><description><![CDATA[<p dir="auto">When we are using a <a href="https://fusionauth.io/docs/v1/tech/connectors/generic-connector" rel="nofollow ugc">generic connector</a> to import users, sometimes we get a timeout message in the logs and a user isn't able to login.</p>
<p dir="auto">How can we increase the timeout?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/643/can-we-increase-timeout-of-the-login-request</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 04:12:30 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/643.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 08 Dec 2020 16:24:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can we increase timeout of the login request? on Tue, 08 Dec 2020 16:25:41 GMT]]></title><description><![CDATA[<p dir="auto">You can increase the timeout of the login request to a connector. If you sign in to the admin UI and navigate to "Settings" and then "Connectors", you can modify either of these settings:</p>
<li>"Connect timeout"</li>
<li>"Read timeout"</li>
<p dir="auto">The default value for these is 2 seconds.</p>
<p dir="auto">There is more documentation on this topic here: <a href="https://fusionauth.io/docs/v1/tech/connectors/generic-connector/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/connectors/generic-connector/</a></p>
<p dir="auto">You can also change them via the API, if that's more in line with your current workflow. That's documented here: <a href="https://fusionauth.io/docs/v1/tech/apis/connectors/generic/#update-the-generic-connector" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/apis/connectors/generic/#update-the-generic-connector</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/1903</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1903</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 08 Dec 2020 16:25:41 GMT</pubDate></item></channel></rss>
