<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[how to get  fresh installation?]]></title><description><![CDATA[<p dir="auto">How do you completely delete fusionAuth in order to get a fresh installation?  I have deleted the helm charts but when I redeploy all my previous history is still intact.  So far the only way I have found to get a clean slate is to delete my kubernetes cluster and reinstall, which is time consuming.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/657/how-to-get-fresh-installation</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 21:14:04 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/657.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 11 Dec 2020 16:43:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to how to get  fresh installation? on Fri, 18 Dec 2020 16:25:49 GMT]]></title><description><![CDATA[<p dir="auto">Sorry, no kub expert here. I'm not sure how to teardown just the database, but I assume you could write a script to connect to the backing database and drop the tables/schema, etc. That might be quicker than dropping the entire cluster.</p>
<p dir="auto">If you figure out a better way, please share!</p>
]]></description><link>https://fusionauth.io/community/forum/post/2001</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2001</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 18 Dec 2020 16:25:49 GMT</pubDate></item><item><title><![CDATA[Reply to how to get  fresh installation? on Tue, 15 Dec 2020 17:02:54 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a>.  We actually do have a kickstart file in place in our Helm chart but in the case that we want to start fresh, I assumed that deleting our Helm chart which includes our Postgresql DB would do just that, but that assumption is incorrect.  So far the only way I have found to start fresh is to delete the EKS cluster and rebuild from the ground up.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1973</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1973</guid><dc:creator><![CDATA[shaunladd]]></dc:creator><pubDate>Tue, 15 Dec 2020 17:02:54 GMT</pubDate></item><item><title><![CDATA[Reply to how to get  fresh installation? on Mon, 14 Dec 2020 04:29:55 GMT]]></title><description><![CDATA[<p dir="auto">Hiya <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/311">@shaunladd</a>.</p>
<p dir="auto">When I need a fresh install locally, I stop FusionAuth and delete the database and the database user. Then I restart FusionAuth and visit the FusionAuth app. This starts up maintenance mode which reinstalls everything. I'm not super familiar with running FusionAuth in k8s, but I think you could do the same thing there.</p>
<p dir="auto">If you want to maintain some configuration between the installations, you may want to write a base configuration Kickstart file. More details here: <a href="https://fusionauth.io/docs/v1/tech/installation-guide/kickstart/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/installation-guide/kickstart/</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/1952</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1952</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 14 Dec 2020 04:29:55 GMT</pubDate></item></channel></rss>
