<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Upgrade issue from 1.21 -&gt; 1.22]]></title><description><![CDATA[<p dir="auto">Has anyone had an issue upgrading FusionAuth 1.21 -&gt; 1.22 due to the <code>state</code> field of the tenant definition in the DB being missing?</p>
<p dir="auto">Logins still work but attempting to view the tenants in the console fails with a template error because of the missing field. It’s not a big issue as we can patch it easily enough, but I wonder if we missed a migration script or something.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/658/upgrade-issue-from-1-21-1-22</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 11:23:19 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/658.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 11 Dec 2020 18:21:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Upgrade issue from 1.21 -&gt; 1.22 on Mon, 14 Dec 2020 16:33:11 GMT]]></title><description><![CDATA[<p dir="auto">Added missing db migration notices for 1.21.0 and 1.22.0.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1961</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1961</guid><dc:creator><![CDATA[robotdan]]></dc:creator><pubDate>Mon, 14 Dec 2020 16:33:11 GMT</pubDate></item><item><title><![CDATA[Reply to Upgrade issue from 1.21 -&gt; 1.22 on Fri, 11 Dec 2020 18:22:15 GMT]]></title><description><![CDATA[<p dir="auto">there is a migration script for 1.21 -&gt; 1.22. It looks like it wasn't mentioned in the release notes, probably because it was a small migration. Perhaps that was an oversight.</p>
<p dir="auto">In general, if you are managing the migrations yourself (rather than having fusionauth do them for you) you should visit <a href="https://fusionauth.io/direct-download/" rel="nofollow ugc">https://fusionauth.io/direct-download/</a> every time there is a release and download the migration scripts and run any new ones.</p>
<p dir="auto"><a href="https://fusionauth.io/docs/v1/tech/installation-guide/upgrade/#database" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/installation-guide/upgrade/#database</a> has more details.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1942</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1942</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 11 Dec 2020 18:22:15 GMT</pubDate></item></channel></rss>
