<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How can I get the system logs?]]></title><description><![CDATA[<p dir="auto">I want to pull the FusionAuth logs (not the event logs, the actual log files) into my log aggregation system. How can I do so?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/673/how-can-i-get-the-system-logs</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 11:57:48 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/673.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Dec 2020 15:12:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How can I get the system logs? on Wed, 16 Dec 2020 15:16:31 GMT]]></title><description><![CDATA[<p dir="auto">If you are running docker or some other container system where logs are written to <code>stdout</code> you should utilize whatever tooling exists to capture that output (<a href="https://docs.docker.com/engine/reference/commandline/logs/" rel="nofollow ugc">docker logs</a> or similar solutions).</p>
<p dir="auto">If you are using a zip file installation or some other installation method which writes log files, you can export the system logs using <a href="https://fusionauth.io/docs/v1/tech/apis/system/#export-system-logs" rel="nofollow ugc">this API call</a>.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1981</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1981</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 16 Dec 2020 15:16:31 GMT</pubDate></item></channel></rss>
