<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Signup&#x2F;Registration flow]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I'm looking for information regarding the registration flow. <a href="https://fusionauth.io/docs/v1/tech/tutorials/register-user-login-api/" rel="nofollow ugc">This page here</a> indicates that there are a handful of API calls that will get the job done.</p>
<p dir="auto">But is there some default form I can use? Just like the authorize form that comes out of the box, I don't need any fancy fields at the moment. I'm looking for a similar out-of-the-box signup form. Does that exist? Are there any docs for how to find and use it?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://fusionauth.io/community/forum/topic/687/signup-registration-flow</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 08:49:43 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/687.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 22 Dec 2020 13:20:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Signup&#x2F;Registration flow on Tue, 22 Dec 2020 17:49:35 GMT]]></title><description><![CDATA[<p dir="auto">Hiya,</p>
<p dir="auto">Thanks for using FusionAuth. Sorry about the confusion.</p>
<p dir="auto">There are three ways to do FusionAuth registration:</p>
<li>using the APIs and building your own UX</li>
<li>using the basic self service registration with hosted login pages &lt;-- this sounds like what you are looking for</li>
<li>using advanced self service registration with hosted login pages (<strong>only available with a paid license</strong> -- <a href="https://fusionauth.io/pricing/" rel="nofollow ugc">pricing starts at $125/month</a> for this and other premium features)</li>
<p dir="auto">Here's some starting docs:</p>
<li><a href="https://fusionauth.io/docs/v1/tech/core-concepts/integration-points/" rel="nofollow ugc">An overview of FusionAuth's integration points</a></li>
<li>The <a href="https://fusionauth.io/docs/v1/tech/themes/" rel="nofollow ugc">theme documentation</a>; theming is how you make the hosted login pages look like your site.</li>
<li><a href="https://fusionauth.io/docs/v1/tech/guides/advanced-registration-forms/" rel="nofollow ugc">The advanced registration guide</a> covers the advanced self service registration, including the differences between <a href="https://fusionauth.io/docs/v1/tech/guides/advanced-registration-forms/#what-is-the-difference-between-advanced-and-basic-registration-forms" rel="nofollow ugc">advanced and basic self service registration</a>.</li>
]]></description><link>https://fusionauth.io/community/forum/post/2033</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2033</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 22 Dec 2020 17:49:35 GMT</pubDate></item></channel></rss>
