<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Preload configuration]]></title><description><![CDATA[<p dir="auto">I would like to define an initial configuration for using at the deployment time.<br />
For instance, would be nice to have some pre-configured app/users/passwords/permissions (can be loaded via script)</p>
<p dir="auto">just in case I need to throw all containers away and start clean but avoid to reconfigure the authentication when the focus would be developing an webapp.</p>
<p dir="auto">It can be something only enabled in development mode.<br />
Is there a way to do it?</p>
<p dir="auto"><em>Pulled over from <a href="https://github.com/FusionAuth/fusionauth-containers/issues/67" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-containers/issues/67</a></em></p>
]]></description><link>https://fusionauth.io/community/forum/topic/690/preload-configuration</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 20:50:13 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/690.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 22 Dec 2020 23:03:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Preload configuration on Tue, 22 Dec 2020 23:03:11 GMT]]></title><description><![CDATA[<p dir="auto">I think you are looking for kickstart: <a href="https://fusionauth.io/docs/v1/tech/installation-guide/kickstart" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/installation-guide/kickstart</a></p>
<p dir="auto">Here's how to run configure Kickstart to run when you are using docker: <a href="https://fusionauth.io/docs/v1/tech/installation-guide/docker/#kickstart" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/installation-guide/docker/#kickstart</a></p>
<p dir="auto">I'm not sure how you are starting your containers, but I imagine you could create and make a kickstart file available in other deployment environments also.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2039</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2039</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 22 Dec 2020 23:03:11 GMT</pubDate></item></channel></rss>
