<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t connect to web interface.]]></title><description><![CDATA[<p dir="auto">I got fusionauth running in a docker in ubuntu and have the 9011 port opened to my ip, but when I put in the servers address(and/or with the ip, and/or http/s) it times out.</p>
<p dir="auto"><a href="http://xxx.xxx.xxx.xxx" rel="nofollow ugc">xxx.xxx.xxx.xxx</a> took too long to respond.</p>
<p dir="auto">I am not sure what to do next, though I still need to setup the .env file which is my next step.</p>
<p dir="auto">Here is some info that might be helpful</p>
<pre><code>~$ docker ps
CONTAINER ID   IMAGE                                                 COMMAND                  CREATED      STATUS          PORTS                    NAMES
77842e098721   fusionauth/fusionauth-app:latest                      "/usr/local/fusionau…"   6 days ago   Up 30 seconds   0.0.0.0:9011-&gt;9011/tcp   ubuntu_fusionauth_1
dcbfc8978431   docker.elastic.co/elasticsearch/elasticsearch:7.8.1   "/tini -- /usr/local…"   6 days ago   Up 30 seconds   9200/tcp, 9300/tcp       ubuntu_search_1
3e5cb9c95e25   postgres:11.9-alpine                                  "docker-entrypoint.s…"   6 days ago   Up 30 seconds   5432/tcp                 ubuntu_db_1
~$ curl -v http://fusionauth:9011
* Could not resolve host: fusionauth
* Closing connection 0
curl: (6) Could not resolve host: fusionauth
ubuntu@ip-172-31-80-105:~$ curl -v localhost:9011
*   Trying 127.0.0.1:9011...
* TCP_NODELAY set
* Connected to localhost (127.0.0.1) port 9011 (#0)
&gt; GET / HTTP/1.1
&gt; Host: localhost:9011
&gt; User-Agent: curl/7.68.0
&gt; Accept: */*
&gt;
* Mark bundle as not supporting multiuse
&lt; HTTP/1.1 302
&lt; Location: /login
&lt; Content-Length: 0
&lt; Date: Mon, 28 Dec 2020 16:26:30 GMT
&lt;
* Connection #0 to host localhost left intact
<p dir="auto">It does look like elasticsearch keeps restarting.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/697/can-t-connect-to-web-interface</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Nov 2026 13:06:12 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/697.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Dec 2020 16:35:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can&#x27;t connect to web interface. on Tue, 29 Dec 2020 21:39:26 GMT]]></title><description><![CDATA[<p dir="auto">How much memory are you giving to the java process?</p>
<p dir="auto">You can also switch to the database search engine and see if removing ES resolves the issue. At that point it might be a resource issue.</p>
<p dir="auto"><a href="https://fusionauth.io/docs/v1/tech/tutorials/switch-search-engines/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/tutorials/switch-search-engines/</a> has instructions on how to change these.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2079</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2079</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 29 Dec 2020 21:39:26 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t connect to web interface. on Mon, 28 Dec 2020 17:39:21 GMT]]></title><description><![CDATA[<p dir="auto">On further inspection, it seems that elasticsearch is using alot of cpu</p>
<pre><code>    PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
  17770 ubuntu    20   0 3143044 907224 181732 S 168.3  45.4   0:18.27 /usr/share/elasticsearch/jdk/bin/java -Xshare:auto -Des.networkaddress.cache.ttl=60 -Des.networkaddress.cache.ne
]]></description><link>https://fusionauth.io/community/forum/post/2065</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2065</guid><dc:creator><![CDATA[xan]]></dc:creator><pubDate>Mon, 28 Dec 2020 17:39:21 GMT</pubDate></item></channel></rss>
