<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is there a way to determine which version of FusionAuth is running?]]></title><description><![CDATA[<p dir="auto">Is there a way to determine which version of FusionAuth is running?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/72/is-there-a-way-to-determine-which-version-of-fusionauth-is-running</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Nov 2026 12:21:58 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/72.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 May 2020 20:58:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is there a way to determine which version of FusionAuth is running? on Mon, 11 May 2020 20:59:55 GMT]]></title><description><![CDATA[<p dir="auto">From the admin UI, go to System / About and you'll see the current version.</p>
<p dir="auto">It is also available via the API by calling <code>/api/status</code> and looking for the <code>version</code> key in the returned object. However, the status response is subject to change.</p>
]]></description><link>https://fusionauth.io/community/forum/post/158</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/158</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 11 May 2020 20:59:55 GMT</pubDate></item></channel></rss>
