<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[fusionauth mysql driver error]]></title><description><![CDATA[<p dir="auto">I have a newbie question, when installing in maintenance mode on windows, i have a backend MySQL instance with fustionauth schema created, but the setup fails with missing jar in spite of placing the MySQL jar in webinf/lib with</p>
<p dir="auto">2021-01-11 4:37:57.874 PM ERROR com.inversoft.maintenance.db.JDBCMaintenanceModeDatabaseService - No [MySQL] Driver found. The [Connector/J jar] may be missing or not be accessible.</p>
<p dir="auto">I have placed the mysql-connector-jar-8.0.21 in the webinf location. Any pointers on how i can get the app running?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/728/fusionauth-mysql-driver-error</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Nov 2026 06:55:43 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/728.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 12 Jan 2021 00:44:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to fusionauth mysql driver error on Tue, 27 Jul 2021 14:28:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/105">@dtokarz1</a></p>
<p dir="auto">Interesting fix.  I will have to consider why your solution worked.  In the end, glad that you were able to get it working!</p>
<p dir="auto">Thanks,<br />
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/3433</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3433</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Tue, 27 Jul 2021 14:28:37 GMT</pubDate></item><item><title><![CDATA[Reply to fusionauth mysql driver error on Sat, 24 Jul 2021 00:43:59 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for replying.  I am following up to let you know what happened.  I clean installed 1.29 and the mysql connector J file was there but I received that error.  I copied the file from a known working install of fusionauth, it prompted me to overwrite the current file which I accepted but I still received that error.  After troubleshooting some more I gave up and did a clean uninstall/reinstall.</p>
<p dir="auto">This time the mysql connector J file was not there.  I copied the same file from the known working install of fusionauth and everything worked.  I can't explain why but a full uninstall/reinstall and copying the mysql file fixed my issue.  Maybe this can help someone else!</p>
]]></description><link>https://fusionauth.io/community/forum/post/3425</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3425</guid><dc:creator><![CDATA[dtokarz1]]></dc:creator><pubDate>Sat, 24 Jul 2021 00:43:59 GMT</pubDate></item><item><title><![CDATA[Reply to fusionauth mysql driver error on Fri, 23 Jul 2021 22:24:26 GMT]]></title><description><![CDATA[<p dir="auto">Also <a href="https://fusionauth.io/community/forum/topic/1151/configuration-fails">https://fusionauth.io/community/forum/topic/1151/configuration-fails</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/3421</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3421</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Fri, 23 Jul 2021 22:24:26 GMT</pubDate></item><item><title><![CDATA[Reply to fusionauth mysql driver error on Fri, 23 Jul 2021 22:22:04 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/105">@dtokarz1</a>!</p>
<p dir="auto">Sorry to hear that you having issues!</p>
<p dir="auto">Are you getting any other errors?  If you have a copy of the error log, that might be helpful as well.</p>
<p dir="auto"><a href="https://fusionauth.io/docs/v1/tech/troubleshooting/#logs" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/troubleshooting/#logs</a></p>
<p dir="auto">It looks like this thread might be related and offer some additional clues?<br />
<a href="https://fusionauth.io/community/forum/topic/605/no-suitable-driver-found-for-jdbc-mysql-localhost-3306-login/7">https://fusionauth.io/community/forum/topic/605/no-suitable-driver-found-for-jdbc-mysql-localhost-3306-login/7</a></p>
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/3420</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3420</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Fri, 23 Jul 2021 22:22:04 GMT</pubDate></item><item><title><![CDATA[Reply to fusionauth mysql driver error on Tue, 20 Jul 2021 14:48:44 GMT]]></title><description><![CDATA[<p dir="auto">Since this topic was never followed up by the user and never closed I thought I would ask this question instead of opening a new topic.</p>
<p dir="auto">I am getting the same error after fresh installing 1.29 on my Windows VPS.  I verified that the mysql-connector-jar-8.0.21 is in the webinf/lib folder.  Obviously I downloaded fusionauth off the site so a network connection is available.  What am I missing?  What else can I check?  This is happening when first connecting to Maintenance Mode.</p>
]]></description><link>https://fusionauth.io/community/forum/post/3382</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3382</guid><dc:creator><![CDATA[dtokarz1]]></dc:creator><pubDate>Tue, 20 Jul 2021 14:48:44 GMT</pubDate></item><item><title><![CDATA[Reply to fusionauth mysql driver error on Thu, 14 Jan 2021 16:31:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/535">@anotherrohit</a> welcome to the FusionAuth community!</p>
<p dir="auto">Does the FusionAuth server with the issue have internet access?</p>
<p dir="auto">Where exactly did you place the jar file? Did you restart the FusionAuth service afterwards?</p>
Dan</p>
]]></description><link>https://fusionauth.io/community/forum/post/2185</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2185</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 14 Jan 2021 16:31:31 GMT</pubDate></item></channel></rss>
