<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can you store off fusionauth config in a file?]]></title><description><![CDATA[<p dir="auto">Is there any easy way to save and restore FusionAuth configuration to different environments?</p>
<p dir="auto">One use case is setting up a local development instance and replicating it it along with a .env file on other developer's machines so they can develop against it.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/73/can-you-store-off-fusionauth-config-in-a-file</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 15:00:11 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/73.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 May 2020 21:33:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can you store off fusionauth config in a file? on Mon, 11 May 2020 21:33:57 GMT]]></title><description><![CDATA[<p dir="auto">You could look at kickstart: <a href="https://fusionauth.io/docs/v1/tech/installation-guide/kickstart" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/installation-guide/kickstart</a></p>
<p dir="auto">Kickstart only works if the other devs' fusionauth instances are going to be starting from scratch.</p>
<p dir="auto">Otherwise you might want to vote for <a href="https://github.com/FusionAuth/fusionauth-issues/issues/560" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/560</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/160</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/160</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 11 May 2020 21:33:57 GMT</pubDate></item></channel></rss>
