<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to access FA Dashboard on a remote server?]]></title><description><![CDATA[<p dir="auto">On my local FA install I type localhost:9011 and I am able to login to the FA Dashboard. I recently put up a server on AWS  that includes FA in the Docker container it is at 35.67.23.x. I thought i could bring up the FA Dashboard by typing 35.67.23.x:9011, but that doesn't work.</p>
<p dir="auto">What do I need to do to be able to log into the AWS FA Dashboard?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/762/how-to-access-fa-dashboard-on-a-remote-server</link><generator>RSS for Node</generator><lastBuildDate>Mon, 05 Oct 2026 12:14:28 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/762.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Jan 2021 02:22:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to access FA Dashboard on a remote server? on Tue, 02 Feb 2021 22:49:41 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">My first question is a) when I setup the dashboard on server A. Can I assume that all the servers (behind a load balancer) will get the same configuration?</p>
<p dir="auto">You need to distribute the configuration file or the environment variables yourself. You could scp the configuration file to each server, for example.</p>
<p dir="auto">b) I want to make sure that FA is using the RDS database and not a local one in each docker container. How can I prove to myself that FA is using the RDS?</p>
<p dir="auto">I'm not sure how you installed this, but you could remove postgresql from the docker-compose file. You can also shut down the RDS instance and see if FusionAuth fails.</p>
<p dir="auto">You can also look for a line in the startup log file that looks like this:</p>
<pre><code>fusionauth_1  | 2021-02-02 9:23:53.070 PM INFO  com.inversoft.jdbc.hikari.DataSourceProvider - Connecting to PostgreSQL database at [jdbc:postgresql://db:5432/fusionauth]
<p dir="auto">This line is connecting to a local postgresql database, but you should see the configuration value pointing to the RDS hostname in yours.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2323</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2323</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 02 Feb 2021 22:49:41 GMT</pubDate></item><item><title><![CDATA[Reply to How to access FA Dashboard on a remote server? on Sat, 30 Jan 2021 19:46:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> said in <a href="/community/forum/post/2252">How to access FA Dashboard on a remote server?</a>:</p>
<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/279">@richb201</a> ,</p>
<p dir="auto">If you are using AWS, you need to make sure you have opened up port 9011 in the security group. Here's some <a href="https://docs.aws.amazon.com/AWSEC2/latest/UserGuide/authorizing-access-to-an-instance.html" rel="nofollow ugc">AWS documentation about that</a>.</p>
<p dir="auto">You probably want a load balancer (nginx or an ALB) in front of your FusionAuth instance to be able to control traffic if needed. This would let you, for example, send different requests based on domain name to different tenants.</p>
<p dir="auto">(Another option, of course, is purchasing <a href="https://fusionauth.io/pricing/" rel="nofollow ugc">FusionAuth Cloud</a> and letting us run your prod server. <img src="https://fusionauth.io/community/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=rcgg4tg866g" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /> )</p>
<p dir="auto">Dan, I got the FA connected to a RDS mySQL and I seems to be able to get in with URL:9011. My first question is a) when I setup the dashboard on server A. Can I assume that all the servers (behind a load balancer) will get the same configuration?  b) I want to make sure that FA is using the RDS database and not a local one in each docker container. How can I prove to myself that FA is using the RDS?</p>
]]></description><link>https://fusionauth.io/community/forum/post/2304</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2304</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Sat, 30 Jan 2021 19:46:14 GMT</pubDate></item><item><title><![CDATA[Reply to How to access FA Dashboard on a remote server? on Fri, 29 Jan 2021 00:35:05 GMT]]></title><description><![CDATA[<p dir="auto">Awesome!</p>
<p dir="auto">But this won't be possible if a load balancer is deciding which instance to send a user to. Unless I should use RDS as the FA database? Has anyone done this successfully?</p>
<p dir="auto">You could run the database locally on an ec2 instance and have both FusionAuth instances connect, but in general you'll be better served having the database on a different server. <a href="https://fusionauth.io/docs/v1/tech/installation-guide/server-layout/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/installation-guide/server-layout/</a> walks through some scenarios.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2294</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2294</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 29 Jan 2021 00:35:05 GMT</pubDate></item><item><title><![CDATA[Reply to How to access FA Dashboard on a remote server? on Wed, 27 Jan 2021 01:56:10 GMT]]></title><description><![CDATA[<p dir="auto">I just found this answer. I will try it out.</p>
<p dir="auto"><a href="https://fusionauth.io/community/forum/topic/721/hosting-on-rds/2?_=1611712258096">https://fusionauth.io/community/forum/topic/721/hosting-on-rds/2?_=1611712258096</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/2270</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2270</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Wed, 27 Jan 2021 01:56:10 GMT</pubDate></item><item><title><![CDATA[Reply to How to access FA Dashboard on a remote server? on Tue, 26 Jan 2021 19:48:40 GMT]]></title><description><![CDATA[<p dir="auto">I managed to open the port 9011 and am now seeing this screen.<br />
<img src="/community/forum/assets/uploads/files/1611687142530-screenshot-from-2021-01-26-13-51-59.png" alt="Screenshot from 2021-01-26 13-51-59.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I was hoping that that configuration that I did on my laptop that get sent up to EC2 from Github would arrive intact. Do I need to re setup FA on the server? Is there a manual way to bring over the entire setup from my laptop? How?</p>
]]></description><link>https://fusionauth.io/community/forum/post/2264</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2264</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Tue, 26 Jan 2021 19:48:40 GMT</pubDate></item><item><title><![CDATA[Reply to How to access FA Dashboard on a remote server? on Tue, 26 Jan 2021 13:25:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> Yes, a production server setup would be great. At this point the product will be freemimum so the finances are a little tight :). The problem with a load balancer is that a user must login into the same copy of FA every time. But this won't be possible if a load balancer is deciding which instance to send a user to. Unless I should use RDS as the FA database? Has anyone done this successfully?</p>
<p dir="auto">This would let you, for example, send different requests based on domain name to different tenants.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2262</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2262</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Tue, 26 Jan 2021 13:25:26 GMT</pubDate></item><item><title><![CDATA[Reply to How to access FA Dashboard on a remote server? on Sun, 24 Jan 2021 21:37:00 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/279">@richb201</a> ,</p>
]]></description><link>https://fusionauth.io/community/forum/post/2252</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2252</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Sun, 24 Jan 2021 21:37:00 GMT</pubDate></item></channel></rss>
