<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Shopify integration]]></title><description><![CDATA[<p dir="auto">Does FusionAuth have any ability to handle credentials management with external OAuth providers such as Shopify?</p>
<p dir="auto">We are looking into implementing login via Shopify, and want to use that OAuth token for some administrative actions on behalf of the user on Shopify.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/791/shopify-integration</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Nov 2026 15:19:14 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/791.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 Feb 2021 15:55:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Shopify integration on Mon, 31 May 2021 15:34:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> said in <a href="/community/forum/post/2603">Shopify integration</a>:</p>
<p dir="auto">Hmmm. That's a bummer that Shopify isn't being responsive. Here's what I have found:</p>
<p dir="auto">Can Shopify Plus acts as an Identity Service provider (physically store the users without using 3r party ISP) and allow other applications (including ours) to authenticate via SAML?</p>
<p dir="auto">Yes, documented here: <a href="https://help.shopify.com/en/manual/shopify-plus/security/saml" rel="nofollow ugc">https://help.shopify.com/en/manual/shopify-plus/security/saml</a></p>
<p dir="auto">This looks like this only works with Shopify users who are in your organization. (<a href="https://www.worktime.com/employee-time-tracking-software" rel="nofollow ugc">Employee time tracking</a>, not time recording.)</p>
<p dir="auto">Can Shopify (Plus or Non-Plus) authenticate users using Shopify accounts.</p>
<p dir="auto">I don't know. This <a href="https://shopify.dev/tutorials/authenticate-with-oauth" rel="nofollow ugc">https://shopify.dev/tutorials/authenticate-with-oauth</a> sure looks like a OIDC flow, but I'm not sure how it works without setting it up. Have you tried to set up an <a href="https://fusionauth.io/docs/v1/tech/identity-providers/openid-connect/" rel="nofollow ugc">OIDC identity provider</a>? That's what I'd do.</p>
<p dir="auto">Dan, You right<br />
It`s works without setting it up, Thank You</p>
]]></description><link>https://fusionauth.io/community/forum/post/3123</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3123</guid><dc:creator><![CDATA[morozovartur302]]></dc:creator><pubDate>Mon, 31 May 2021 15:34:31 GMT</pubDate></item><item><title><![CDATA[Reply to Shopify integration on Fri, 12 Mar 2021 17:56:17 GMT]]></title><description><![CDATA[<p dir="auto">Hmmm. That's a bummer that Shopify isn't being responsive. Here's what I have found:</p>
<p dir="auto">This looks like this only works with Shopify users who are in your organization. (Employee IAM, not CIAM.)</p>
]]></description><link>https://fusionauth.io/community/forum/post/2603</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2603</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 12 Mar 2021 17:56:17 GMT</pubDate></item><item><title><![CDATA[Reply to Shopify integration on Wed, 10 Mar 2021 12:06:26 GMT]]></title><description><![CDATA[<p dir="auto">I am thinking about it the whole week and could not grasp all the facts, especially at Shopify end. I asked the questions on their forum, contacted them directly. Nothing.<br />
There are 2 main questions I am looking to get answers to:</p>
<li>Can Shopify Plus acts as an Identity Service provider (physically store the users without using 3r party ISP) and allow other applications (including ours) to authenticate via SAML?</li>
<li>Can Shopify (Plus or Non-Plus) authenticate users using Shopify accounts. Something like Shopify Social Connection. It appears so, according to Auth0 offering: <a href="https://auth0.com/docs/connections/social/shopify#set-up-app-in-shopify" rel="nofollow ugc">https://auth0.com/docs/connections/social/shopify#set-up-app-in-shopify</a>. This would require that our app is installed in Shopify as "Shopify Custom App"<br />
But I could not find any article about Shopify authenticating (installed app users), not apps via Oauth.</li>
]]></description><link>https://fusionauth.io/community/forum/post/2573</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2573</guid><dc:creator><![CDATA[milan.agatonovic]]></dc:creator><pubDate>Wed, 10 Mar 2021 12:06:26 GMT</pubDate></item><item><title><![CDATA[Reply to Shopify integration on Thu, 04 Feb 2021 16:01:07 GMT]]></title><description><![CDATA[<p dir="auto">I haven't heard of this happening, but if Shopify supports OIDC or SAML v2 you can use an IdP config.</p>
<p dir="auto"><a href="https://fusionauth.io/docs/v1/tech/identity-providers/openid-connect/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/identity-providers/openid-connect/</a> documents it for instance. It appears <a href="https://shopify.dev/tutorials/authenticate-with-oauth" rel="nofollow ugc">Shopify supports OAuth</a> so the OIDC provider should work.</p>
<p dir="auto">Important things to note:</p>
<li>if you need to pass additional parameters to certain endpoints, turn off 'discover endpoints' and you can add them. See <a href="https://fusionauth.io/community/forum/topic/663/force-google-account-selection-on-every-login?_=1612454251976">https://fusionauth.io/community/forum/topic/663/force-google-account-selection-on-every-login?_=1612454251976</a> for more</li>
<li>the token returned by the external OAuth provider will be available on <code>user.registrations[x].tokens</code> with the key of the provider id. See <a href="https://fusionauth.io/docs/v1/tech/apis/identity-providers/openid-connect/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/apis/identity-providers/openid-connect/</a> for more details</li>
<li>the links above are for OIDC, but SAML integrations are also supported; review the analogous documentation.</li>
]]></description><link>https://fusionauth.io/community/forum/post/2330</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2330</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 04 Feb 2021 16:01:07 GMT</pubDate></item></channel></rss>
