<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[fusioAuth install is damaged?]]></title><description><![CDATA[<p dir="auto">I am typing localhost:9011 but i get this error:</p>
<p dir="auto"><a href="http://localhost:9011/maintenance-mode-silent-configuration-failed" rel="nofollow ugc">http://localhost:9011/maintenance-mode-silent-configuration-failed</a></p>
<p dir="auto">Does this mean that my local FA install is damaged? How can I check this?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/815/fusioauth-install-is-damaged</link><generator>RSS for Node</generator><lastBuildDate>Mon, 05 Oct 2026 11:05:10 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/815.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Feb 2021 18:33:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to fusioAuth install is damaged? on Fri, 26 Feb 2021 21:56:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/56">@maciej-wisniowski</a> That was done when we found that there was a bug in</p>
<p dir="auto">#FROM fusionauth/fusionauth-app:1.19.4</p>
<p dir="auto">and we replaced it with:</p>
<p dir="auto">FROM fusionauth/fusionauth-app:1.19.7</p>
]]></description><link>https://fusionauth.io/community/forum/post/2503</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2503</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Fri, 26 Feb 2021 21:56:17 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Fri, 26 Feb 2021 11:21:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/56">@maciej-wisniowski</a> thanks for the comment. The fa instance is in EACH container. At least that is my plan. Each container has apache, fa, AWS-CLI, php-fpm, and my application code. The application talks with mysql on RDS just fine. The plan is for fa (in each container) to speak with fusionauthdb  which is also up on mysql RDS. So the container on my laptop has its own fa that talks to fusionauthdb on RDS. At least that is the plan!</p>
<p dir="auto">I will check to see that I have granted permission to my laptop by putting in the question to AWS support for RDS. I am assuming in 2021 that I don't need to serialize access to the fusionauthdb like we use to be required to do in the old mini days?</p>
<p dir="auto">I have a copy running on my laptop for development purposes. I also plan to have a staging server which is just another copy with xdebug and development logging enabled, and finally the actual deployment  server. The servers will all be Lightsail.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2501</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2501</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Fri, 26 Feb 2021 11:21:58 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Fri, 26 Feb 2021 06:58:46 GMT]]></title><description><![CDATA[<p dir="auto">Where is your FA instance? On EC2 or localhost? Seems to be localhost from your screen. If so, then can you connect to RDS from the same machine (localhost probably) as one where is your FA instance? Previously you had errors like: "Host '73.188.125.114' is blocked because of many connection errors; unblock with 'mysqladmin flush-hosts'", so maybe it is your localhost IP that is blocked?</p>
<p dir="auto">Also, if you get error 500 from FA then you should be able to see more detailed logs on the docker-compose console or using docker-compose logs fusionauth</p>
]]></description><link>https://fusionauth.io/community/forum/post/2500</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2500</guid><dc:creator><![CDATA[maciej.wisniowski]]></dc:creator><pubDate>Fri, 26 Feb 2021 06:58:46 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Fri, 26 Feb 2021 02:27:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3">@robotdan</a> said in <a href="/community/forum/post/2496">fusioAuth install is damaged?</a>:</p>
<p dir="auto"><a href="http://database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com" rel="nofollow ugc">database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com</a></p>
<p dir="auto">What is strange is that I can get into it (RDS mysql) fine from the ec2 directly. I just don't know how that was set up (what connection string is being used)?</p>
<p dir="auto">As I think I said, using the path and database name you recommend</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1614306421306-screenshot-from-2021-02-25-21-25-42.png" alt="Screenshot from 2021-02-25 21-25-42.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Causes a 500 error:<br />
HTTP ERROR 500</p>
]]></description><link>https://fusionauth.io/community/forum/post/2497</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2497</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Fri, 26 Feb 2021 02:27:16 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Thu, 25 Feb 2021 16:42:29 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">ERROR 2005 (HY000): Unknown MySQL server host '<a href="http://database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com/fusionauthdb" rel="nofollow ugc">database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com/fusionauthdb</a>'</p>
<p dir="auto">That is an invalid host name so that error makes sense. The host is <code>database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com</code> and the database is <code>fusionauthdb</code>.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2496</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2496</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 25 Feb 2021 16:42:29 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Thu, 25 Feb 2021 16:40:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/56">@maciej-wisniowski</a> When I try this string I get:</p>
<p dir="auto">ERROR 2005 (HY000): Unknown MySQL server host '<a href="http://database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com/fusionauthdb" rel="nofollow ugc">database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com/fusionauthdb</a>' (2)</p>
<p dir="auto">mysql -h <a href="http://database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com/fusionauthdb" rel="nofollow ugc">database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com/fusionauthdb</a> -P 3306 -u admin -p</p>
<p dir="auto">That is why seeing what a working connection string from the EC2 is would solve the problem.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2492</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2492</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Thu, 25 Feb 2021 16:40:40 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Thu, 25 Feb 2021 16:18:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/279">@richb201</a> have you tried to connect to this RDS database using any other MySQL client from the same machine? Maybe there is some firewall or permissions issue with RDS</p>
]]></description><link>https://fusionauth.io/community/forum/post/2491</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2491</guid><dc:creator><![CDATA[maciej.wisniowski]]></dc:creator><pubDate>Thu, 25 Feb 2021 16:18:37 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Thu, 25 Feb 2021 16:17:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3">@robotdan</a> Dan, putting that port in causes the RDS server to time out. It is repeatable. Is there some other way to see what the connection string is set to on the EC2? Perhaps there is a config file? I do have filezilla attached to that server.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2490</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2490</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Thu, 25 Feb 2021 16:17:34 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Thu, 25 Feb 2021 15:29:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/279">@richb201</a> said in <a href="/community/forum/post/2485">fusioAuth install is damaged?</a>:</p>
<p dir="auto">DATABASE_URL: jdbc:mysql://database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com/fusionauthdb</p>
<p dir="auto">You are still missing the port in this string (as I mentioned above).</p>
<p dir="auto"><code>DATABASE_URL: jdbc:mysql://database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com:3306/fusionauthdb</code>.</p>
<p dir="auto">You cannot view the connection string from the UI at runtime.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2489</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2489</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 25 Feb 2021 15:29:59 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Thu, 25 Feb 2021 15:25:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/56">@maciej-wisniowski</a> Thanks. I'll ask the guy who rebuilt it why he did that?</p>
<p dir="auto">One more question. I have a copy of FA running on Ec2 that is able to talk to the RDS mysql  fine. How can I see, from the UI, what the connection string being used is?</p>
]]></description><link>https://fusionauth.io/community/forum/post/2487</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2487</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Thu, 25 Feb 2021 15:25:27 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Thu, 25 Feb 2021 12:09:39 GMT]]></title><description><![CDATA[<p dir="auto">Have you tried with original docker image instead of building FA by yourself? Seems (from the first post) that you have some customized dockerfile/image for fusionauth so maybe there is an issue</p>
<pre><code>fusionauth:
  container_name: fusionauth-app
  build :
    context: ./fusionAuth
    dockerfile: Dockerfile
]]></description><link>https://fusionauth.io/community/forum/post/2486</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2486</guid><dc:creator><![CDATA[maciej.wisniowski]]></dc:creator><pubDate>Thu, 25 Feb 2021 12:09:39 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Thu, 25 Feb 2021 12:02:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/56">@maciej-wisniowski</a> Thanks. I took care of that but I still get this error over and over again in the docker log.</p>
<p dir="auto">2021-02-25 11:59:30.438 AM ERROR com.inversoft.maintenance.db.JDBCMaintenanceModeDatabaseService - Configuration [database.url] is invalid. It must begin with either jdbc:mysql: or jdbc:postgresql:</p>
<p dir="auto">Here is part of the docker-compose:</p>
<p dir="auto">environment:<br />
DATABASE_URL: jdbc:mysql://database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com/fusionauthdb<br />
DATABASE_ROOT_USERNAME: ${DATABASE_ROOT_USERNAME} # Enter here the Database username for connection<br />
DATABASE_ROOT_PASSWORD: ${DATABASE_PASSWORD}<br />
# Prior to version 1.19.0, use this deprecated name<br />
# DATABASE_USER: ${DATABASE_USER}<br />
DATABASE_USERNAME: ${DATABASE_USERNAME}<br />
DATABASE_PASSWORD: ${DATABASE_PASSWORD}<br />
# Prior to version 1.19.0, use this deprecated names<br />
# FUSIONAUTH_MEMORY: ${FUSIONAUTH_MEMORY}<br />
# FUSIONAUTH_SEARCH_ENGINE_TYPE: database<br />
# FUSIONAUTH_URL: <a href="http://fusionauth:9011" rel="nofollow ugc">http://fusionauth:9011</a><br />
# FUSIONAUTH_RUNTIME_MODE: development<br />
FUSIONAUTH_APP_MEMORY: ${FUSIONAUTH_MEMORY}<br />
FUSIONAUTH_APP_RUNTIME_MODE: development<br />
FUSIONAUTH_APP_URL: <a href="http://fusionauth:9011" rel="nofollow ugc">http://fusionauth:9011</a><br />
SEARCH_TYPE: database<br />
FUSIONAUTH_APP_SILENT_MODE: "false"</p>
]]></description><link>https://fusionauth.io/community/forum/post/2485</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2485</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Thu, 25 Feb 2021 12:02:38 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Thu, 25 Feb 2021 07:21:42 GMT]]></title><description><![CDATA[<p dir="auto">Seems you have a typo in the environment variable name. Instead of DATABASE_ROOT_USER it should be DATABASE_ROOT_USERNAME. Maybe this will resolve the problem.</p>
<p dir="auto">I have a docker-compose that uses local image of postgresql. For the reference I'm pasting my config below (there are some minor differences in the real version but these should not be relevant):</p>
<pre><code>fusion_db:
    image: postgres:9.6
    environment:
      PGDATA: /var/lib/postgresql/data/pgdata
      POSTGRES_USER: postgres
      POSTGRES_PASSWORD: some.password
    networks:
      - fusion_db
    restart: unless-stopped
    ports:
      - 5432:5432
    volumes:
      - fusion_db_data:/var/lib/postgresql/data
  fusionauth:
    image: fusionauth/fusionauth-app:1.24.0
    depends_on:
      - fusion_db
      - elasticsearch
    environment:
      DATABASE_URL: jdbc:postgresql://fusion_db:5432/fusionauth
      DATABASE_ROOT_USERNAME: postgres
      DATABASE_ROOT_PASSWORD: some.password
      DATABASE_USERNAME: fusionauth
      DATABASE_PASSWORD: some.password
      FUSIONAUTH_APP_MEMORY: 256M
      SEARCH_TYPE: elasticsearch
      FUSIONAUTH_APP_SILENT_MODE: "true"
      SEARCH_SERVERS: http://elasticsearch:9200
      FUSIONAUTH_APP_URL: https://auth.mylocal.domain
      FUSIONAUTH_APP_KICKSTART_FILE: docker-fusionauth-kickstart/kickstart.json
    networks:
      - fusion_db
      - fusion_search
      - default
    ports:
      - 9011:9011
    volumes:
      - fusion_fa_config:/usr/local/fusionauth/config
      - ./docker-fusionauth-kickstart:/docker-fusionauth-kickstart
volumes:
  fusion_db_data:
  fusion_fa_config:
]]></description><link>https://fusionauth.io/community/forum/post/2480</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2480</guid><dc:creator><![CDATA[maciej.wisniowski]]></dc:creator><pubDate>Thu, 25 Feb 2021 07:21:42 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Wed, 24 Feb 2021 21:20:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3">@robotdan</a> said in <a href="/community/forum/post/2477">fusioAuth install is damaged?</a>:</p>
<p dir="auto">mysql://database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com</p>
<p dir="auto">I hate to be a pain. Here are the fields from the maint mode.<br />
<img src="/community/forum/assets/uploads/files/1614201560858-screenshot-from-2021-02-24-16-18-06.png" alt="Screenshot from 2021-02-24 16-18-06.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">and here is the resulting screen:</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1614201604715-screenshot-from-2021-02-24-16-19-47.png" alt="Screenshot from 2021-02-24 16-19-47.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">did I follow your description of the fields correctly?</p>
]]></description><link>https://fusionauth.io/community/forum/post/2479</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2479</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Wed, 24 Feb 2021 21:20:41 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Wed, 24 Feb 2021 16:36:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3">@robotdan</a> said in <a href="/community/forum/post/2468">fusioAuth install is damaged?</a>:</p>
<p dir="auto">jdbc:mysql://database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com:3306/fusionauthdb</p>
<p dir="auto">You don't want to paste in the full JDBC string into the UI, it has separate fields for host, database and port.</p>
<p dir="auto">This string <code>jdbc:mysql://database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com:3306/fusionauthdb</code> could be used in a Docker configuration or directly in the <code>fusionauth.properties</code> file. This JDBC string is constructed as <code>schema:database _type://host:port/database</code>.</p>
<p dir="auto">If you are using Maintenance Mode, then you will need to use the appropriate parts of this string to fill in the fields.</p>
<p dir="auto">If you are entering maintenance mode it is because FusionAuth cannot connect to the database as configured, the console messages will describe why it cannot connect, and once you configure the field values in the UI it will tell you if it cannot connect.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2477</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2477</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 24 Feb 2021 16:36:08 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Wed, 24 Feb 2021 13:30:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3">@robotdan</a> and Dan I did add the port and the errors in the docker log seems to have gone away. But this causes the following error in the browser. To get around this I need to reboot the rds</p>
<p dir="auto">A PHP Error was encountered<br />
Severity: Warning</p>
<p dir="auto">Message: mysqli::real_connect(): (HY000/1129): Host '73.188.125.114' is blocked because of many connection errors; unblock with 'mysqladmin flush-hosts'</p>
<p dir="auto">Filename: mysqli/mysqli_driver.php</p>
<p dir="auto">Line Number: 203</p>
<p dir="auto">Backtrace:</p>
<p dir="auto">File: /app/application/core/MY_Loader.php<br />
Line: 277<br />
Function: database</p>
<p dir="auto">File: /app/application/controllers/Configure.php<br />
Line: 29<br />
Function: __construct</p>
<p dir="auto">File: /app/index.php<br />
Line: 325<br />
Function: require_once</p>
<p dir="auto">A Database Error Occurred<br />
Unable to connect to your database server using the provided settings.</p>
<p dir="auto">Filename: controllers/Configure.php</p>
<p dir="auto">Line Number: 29</p>
<p dir="auto">P.S. I went back to the original connection string and it seems to 1) not get the "is blocked" error above 2) gets the error below in the docker log (this is just a small sampling of it) 3) allows me to connect to <a href="http://localhost:9011/maintenance-mode-database-configuration" rel="nofollow ugc">http://localhost:9011/maintenance-mode-database-configuration</a>, OK, although I can't figure out what to enter in the maint mode Database Type section.</p>
<p dir="auto">2021-02-24 11:00:19.765 AM ERROR com.inversoft.maintenance.db.JDBCMaintenanceModeDatabaseService - Configuration [database.url] is invalid. It must begin with either jdbc:mysql: or jdbc:postgresql:<br />
2021-02-24 11:00:19.771 AM ERROR com.inversoft.maintenance.db.JDBCURL - Could not parse jdbcString [jdbc:mysql:database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com]<br />
2021-02-24 11:00:19.771 AM ERROR com.inversoft.maintenance.db.JDBCMaintenanceModeDatabaseService - Configuration [database.url] is invalid. It must begin with either jdbc:mysql: or jdbc:postgresql:<br />
2021-02-24 11:00:29.763 AM ERROR com.inversoft.maintenance.db.JDBCURL - Could not parse jdbcString [jdbc:mysql:database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com]</p>
]]></description><link>https://fusionauth.io/community/forum/post/2476</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2476</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Wed, 24 Feb 2021 13:30:39 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Wed, 24 Feb 2021 11:13:16 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Dan. Interestingly, now when i type localhost:9011, I am getting  the attached browser window at <a href="http://localhost:9011/maintenance-mode-database-configuration" rel="nofollow ugc">http://localhost:9011/maintenance-mode-database-configuration</a>. BTW, I have no idea why it is now <em>almost</em> working. <img src="/community/forum/assets/uploads/files/1614164677268-screenshot-from-2021-02-24-06-03-08.png" alt="Screenshot from 2021-02-24 06-03-08.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I am assuming that maint mode is running because fa can;'t connect to my rds mysql.</p>
<p dir="auto">Into tyhe main mode input screen, now I see a field for port and one for database.</p>
<p dir="auto">I tried pasting what you gave me,<br />
<p dir="auto">but now I get</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1614164920748-screenshot-from-2021-02-24-06-08-16.png" alt="Screenshot from 2021-02-24 06-08-16.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Then I tried<br />
URL: jdbc:mysql:database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com<br />
Port:3306<br />
databse: fusionauthdb<br />
TLS enabled : no</p>
<p dir="auto">I still get the error 500.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2475</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2475</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Wed, 24 Feb 2021 11:13:16 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Tue, 23 Feb 2021 19:01:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/279">@richb201</a> said in <a href="/community/forum/post/2443">fusioAuth install is damaged?</a>:</p>
<p dir="auto">jdbc:mysql://database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com/fusionauthdb</p>
<p dir="auto">You need to specify the <code>port</code> on the JDBC string. Try this <code>jdbc:mysql://database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com:3306/fusionauthdb</code>.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2468</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2468</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 23 Feb 2021 19:01:08 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Tue, 23 Feb 2021 18:40:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/279">@richb201</a> said in <a href="/community/forum/post/2443">fusioAuth install is damaged?</a>:</p>
<p dir="auto">FUSIONAUTH_APP_SILENT-MODE: "false"</p>
<p dir="auto">I found that I am getting a message from the mysql (this is RDS) that I have reached my limit on errors. Something had changed in my <code>docker-compose.yml</code>. The only way to get to reset the error count was to reboot the mysql server and use my "back in time". I restored numerous days in the past (back to Feb 19th) and now things appear stable again.  Seems to be a bug in the fa image? I am using 1.19.7. I will post the current errors up to the github site and see if anyone knows anything. Here they are just for giggles:</p>
<pre><code>2021-02-23 6:23:49.866 AM INFO  com.inversoft.maintenance.MaintenanceModePoller - Poller started to Wait for configuration to be completed.
23-Feb-2021 06:23:49.889 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-9011"]
23-Feb-2021 06:23:49.897 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["https-jsse-nio-9013"]
23-Feb-2021 06:23:49.898 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-127.0.0.1-9019"]
23-Feb-2021 06:23:49.899 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 3295 ms
2021-02-23 6:23:54.907 AM ERROR com.inversoft.maintenance.db.JDBCURL - Could not parse jdbcString [jdbc:mysql:database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com]
2021-02-23 6:23:54.908 AM ERROR com.inversoft.maintenance.db.JDBCMaintenanceModeDatabaseService - Configuration [database.url] is invalid. It must begin with either jdbc:mysql: or jdbc:postgresql:
2021-02-23 6:23:54.927 AM ERROR com.inversoft.maintenance.db.JDBCURL - Could not parse jdbcString [jdbc:mysql:database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com]
2021-02-23 6:23:54.928 AM ERROR com.inversoft.maintenance.db.JDBCMaintenanceModeDatabaseService - Configuration [database.url] is invalid. It must begin with either jdbc:mysql: or jdbc:postgresql:
2021-02-23 6:24:05.346 AM ERROR com.inversoft.maintenance.db.JDBCURL - Could not parse jdbcString [jdbc:mysql:database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com]
2021-02-23 6:24:05.347 AM ERROR com.inversoft.maintenance.db.JDBCMaintenanceModeDatabaseService - Configuration [database.url] is invalid. It must begin with either jdbc:mysql: or jdbc:postgresql:
2021-02-23 6:24:05.359 AM ERROR com.inversoft.maintenance.db.JDBCURL - Could not parse jdbcString [jdbc:mysql:database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com]
2021-02-23 6:24:05.359 AM ERROR com.inversoft.maintenance.db.JDBCMaintenanceModeDatabaseService - Configuration [database.url] is invalid. It must begin with either jdbc:mysql: or jdbc:postgresql:
2021-02-23 6:24:16.748 AM ERROR com.inversoft.maintenance.db.JDBCURL - Could not parse jdbcString [jdbc:mysql:database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com]
2021-02-23 6:24:16.748 AM ERROR com.inversoft.maintenance.db.JDBCMaintenanceModeDatabaseService - Configuration [database.url] is invalid. It must begin with either jdbc:mysql: or jdbc:postgresql:
2021-02-23 6:24:16.762 AM ERROR com.inversoft.maintenance.db.JDBCURL - Could not parse jdbcString [jdbc:mysql:database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com]
2021-02-23 6:24:16.763 AM ERROR com.inversoft.maintenance.db.JDBCMaintenanceModeDatabaseService - Configuration [database.url] is invalid. It must begin with either jdbc:mysql: or jdbc:postgresql:
2021-02-23 6:24:24.892 AM ERROR com.inversoft.maintenance.db.JDBCURL - Could not parse jdbcString [jdbc:mysql:database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com]
2021-02-23 6:24:24.893 AM ERROR com.inversoft.maintenance.db.JDBCMaintenanceModeDatabaseService - Configuration [database.url] is invalid. It must begin with either jdbc:mysql: or jdbc:postgresql:
2021-02-23 6:24:24.901 AM ERROR com.inversoft.maintenance.db.JDBCURL - Could not parse jdbcString [jdbc:mysql:database-2.cwymdn16cxes.us-east-1.rds.amazonaws.com]
2021-02-23 6:24:24.901 AM ERROR com.inversoft.maintenance.db.JDBCMaintenanceModeDatabaseService - Configuration [database.url] is invalid. It must begin with either jdbc:mysql: or jdbc:postgresql:
]]></description><link>https://fusionauth.io/community/forum/post/2463</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2463</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Tue, 23 Feb 2021 18:40:32 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Mon, 22 Feb 2021 14:05:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/56">@maciej-wisniowski</a> Thanks. That seems to work now! At least the error in my docker log went away. Now to test....</p>
]]></description><link>https://fusionauth.io/community/forum/post/2457</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2457</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Mon, 22 Feb 2021 14:05:31 GMT</pubDate></item><item><title><![CDATA[Reply to fusioAuth install is damaged? on Mon, 22 Feb 2021 07:35:20 GMT]]></title><description><![CDATA[<p dir="auto">Ah.. seems I've made a typo, please try with all underscores in FUSIONAUTH_APP_SILENT_MODE (instead of FUSIONAUTH_APP_SILENT-MODE).</p>
]]></description><link>https://fusionauth.io/community/forum/post/2456</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2456</guid><dc:creator><![CDATA[maciej.wisniowski]]></dc:creator><pubDate>Mon, 22 Feb 2021 07:35:20 GMT</pubDate></item></channel></rss>
