<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can I temporarily disable logging into an application?]]></title><description><![CDATA[<p dir="auto">I have a FusionAuth application for which I want to disable authentication temporarily.</p>
<p dir="auto">Is this possible?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/818/can-i-temporarily-disable-logging-into-an-application</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 03:22:05 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/818.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Feb 2021 21:28:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can I temporarily disable logging into an application? on Mon, 15 Feb 2021 21:30:11 GMT]]></title><description><![CDATA[<p dir="auto">Yes, you can disable one or more applications.</p>
<p dir="auto">This operation can be reversed, and while an application is disabled, login requests to fail with a 400 error for all users.</p>
<p dir="auto">Navigate to "Applications -&gt; Deactivate (gray button)" to disable/deactivate an application.</p>
<p dir="auto">To re-enable it from the admin UI, you'll need to 'view inactive', which is the button next to the green '+' sign on the list applications page.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2410</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2410</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 15 Feb 2021 21:30:11 GMT</pubDate></item></channel></rss>
