<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[where to enter smtp credentials]]></title><description><![CDATA[<p dir="auto">I am getting this error when I try to send a test email through tenents:</p>
<p dir="auto">Unable to send email via JavaMail535 Authentication Credentials Invalid</p>
<p dir="auto">Where should I enter the credentials that my smtp server needs?<br />
The instructs say to enable smtp. Where is that done? I dont see an enable toggle.</p>
<p dir="auto">Also while I have your attention, I want to have my users initiate a passwordless registration/login via my wordpress site. I will be self hosting this.  Can you point to any docs that describe such a scenerio?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/842/where-to-enter-smtp-credentials</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Nov 2026 16:03:20 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/842.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Mar 2021 18:18:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to where to enter smtp credentials on Mon, 08 Mar 2021 16:04:25 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/279">@richb201</a> , appreciate the UI suggestions! I'll take a look as we definitely don't want folks to be confused/frustrated by the user interface.</p>
<p dir="auto">Cheers,<br />
Dan</p>
]]></description><link>https://fusionauth.io/community/forum/post/2555</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2555</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 08 Mar 2021 16:04:25 GMT</pubDate></item><item><title><![CDATA[Reply to where to enter smtp credentials on Fri, 05 Mar 2021 02:57:09 GMT]]></title><description><![CDATA[<p dir="auto">really appreciate the feedback and glad it wasn't a deeper bug. I'll convey this feedback to the product team and we'll see if we can make it clearer.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2536</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2536</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 05 Mar 2021 02:57:09 GMT</pubDate></item><item><title><![CDATA[Reply to where to enter smtp credentials on Fri, 05 Mar 2021 00:36:27 GMT]]></title><description><![CDATA[<p dir="auto">That was there! I was wondering about that but was scared to eff with it. That is the way to enter a password? You guys should change the label to "change SMTP password". Even now I would be concerned that it change my SMTP password on AWS.</p>
<p dir="auto">Dan, playing with trial and error is a great way to eff things up on an almost working system.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2534</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2534</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Fri, 05 Mar 2021 00:36:27 GMT</pubDate></item><item><title><![CDATA[Reply to where to enter smtp credentials on Fri, 05 Mar 2021 00:31:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/279">@richb201</a></p>
<p dir="auto">Hmm. Thanks for sharing this so others can benefit from it! That sounds pretty frustrating.</p>
<p dir="auto">Out of curiosity, did you see the <code>Change password</code> toggle field on the email settings page? Or was that missing too?</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1614904281487-screen-shot-2021-03-04-at-5.29.21-pm.png" alt="Screen Shot 2021-03-04 at 5.29.21 PM.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fusionauth.io/community/forum/post/2533</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2533</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 05 Mar 2021 00:31:27 GMT</pubDate></item><item><title><![CDATA[Reply to where to enter smtp credentials on Thu, 04 Mar 2021 23:44:08 GMT]]></title><description><![CDATA[<p dir="auto">OK. I figured it out and I am posting this for all the other users who get this error with the SMTP test. It only took me about 8 hours to figure this out :(.  The password field <strong>disappears</strong> after a password has been attempted, <strong>even if it is wrong</strong>. The only way to fix it is to delete the  <strong>entire tenant</strong> and enter the data again. This should be documented. In searching through the forum this is a very common problem with a super simple answer. The password field just disappears by itself. I guess it is a feature:).</p>
]]></description><link>https://fusionauth.io/community/forum/post/2531</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2531</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Thu, 04 Mar 2021 23:44:08 GMT</pubDate></item><item><title><![CDATA[Reply to where to enter smtp credentials on Thu, 04 Mar 2021 18:21:31 GMT]]></title><description><![CDATA[<p dir="auto">Dan, SES requires a SMTP username and password. I have them. But where do I enter them in the FA UI? I do see a place for a username in the SMTP setup in Tenant. But how about the password? where does that go?</p>
]]></description><link>https://fusionauth.io/community/forum/post/2530</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2530</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Thu, 04 Mar 2021 18:21:31 GMT</pubDate></item><item><title><![CDATA[Reply to where to enter smtp credentials on Thu, 04 Mar 2021 02:33:25 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Dan. I did have it going previously with SES but I lost that configuration. Is there some fusionauth config file that I could search my hard drive for? That could save me a huge amount of effort.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2529</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2529</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Thu, 04 Mar 2021 02:33:25 GMT</pubDate></item><item><title><![CDATA[Reply to where to enter smtp credentials on Wed, 03 Mar 2021 16:19:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/279">@richb201</a> ,</p>
<p dir="auto">You can configure the email settings on a per-tenant basis. Here's some documentation on the available settings: <a href="https://fusionauth.io/docs/v1/tech/core-concepts/tenants/#email" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/core-concepts/tenants/#email</a></p>
<p dir="auto">I'm not sure which SMTP server you are using, but if they require custom headers (which I believe AWS SES does) then there's an open issue for that: <a href="https://github.com/FusionAuth/fusionauth-issues/issues/628" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/628</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/2526</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2526</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 03 Mar 2021 16:19:18 GMT</pubDate></item></channel></rss>
