<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Are the post and get forms of the user search API equivalent?]]></title><description><![CDATA[<p dir="auto">I noticed that the FusionAuth java client only <a href="https://github.com/FusionAuth/fusionauth-java-client/blob/master/src/main/java/io/fusionauth/client/FusionAuthClient.java#L3256" rel="nofollow ugc">posts user searches</a>, it doesn't perform a get.</p>
<p dir="auto">Will that be an issue if I am using the database search engine?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/865/are-the-post-and-get-forms-of-the-user-search-api-equivalent</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 14:53:47 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/865.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Mar 2021 00:31:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Are the post and get forms of the user search API equivalent? on Tue, 09 Mar 2021 00:32:54 GMT]]></title><description><![CDATA[<p dir="auto">Yes, they are equivalent. Building this JSON:</p>
<pre><code>{
  "search": {
    "queryString": "fusionauth.io"
<p dir="auto">and posting it is equivalent to a GET with <code>queryString=fusionauth.io</code>.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2564</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2564</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 09 Mar 2021 00:32:54 GMT</pubDate></item></channel></rss>
