<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can you use the same template for the forgot password and send password emails?]]></title><description><![CDATA[<p dir="auto">Since both APIs are technically the same, is there a way to use the email template defined for the Setup Password with the Forgot Password API?</p>
<p dir="auto">(ported discussion over from <a href="https://github.com/FusionAuth/fusionauth-issues/issues/1121" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/1121</a> )</p>
]]></description><link>https://fusionauth.io/community/forum/topic/878/can-you-use-the-same-template-for-the-forgot-password-and-send-password-emails</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 23:03:57 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/878.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Mar 2021 16:18:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can you use the same template for the forgot password and send password emails? on Fri, 12 Mar 2021 16:18:39 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Yes. Navigate to 'Tenants -&gt; your tenant -&gt; Email' and you can set 'Setup password' and 'Forgot password' to be the same template.</p>
<p dir="auto">There may be template variable differences, please consult the documentation and ensure you are checking for existence before you rely on them:</p>
<p dir="auto"><a href="https://fusionauth.io/docs/v1/tech/email-templates/email-templates/#setup-password" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/email-templates/email-templates/#setup-password</a></p>
<p dir="auto"><a href="https://fusionauth.io/docs/v1/tech/email-templates/email-templates/#change-password" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/email-templates/email-templates/#change-password</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/2601</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2601</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 12 Mar 2021 16:18:39 GMT</pubDate></item></channel></rss>
