<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can I have physical as well as logical separation of my tenants in FusionAuth?]]></title><description><![CDATA[<p dir="auto">I need the ability to have some tenants isolated logically and others geographically. Is this possible?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/897/can-i-have-physical-as-well-as-logical-separation-of-my-tenants-in-fusionauth</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 14:59:46 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/897.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Mar 2021 23:15:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can I have physical as well as logical separation of my tenants in FusionAuth? on Fri, 19 Mar 2021 23:17:09 GMT]]></title><description><![CDATA[<p dir="auto">Tenants are separated logically, with users, identity providers, and applications all separate.</p>
<p dir="auto">If you need physical or geographic separation (for instance, to host users in <code>tenant A</code> in the USA and users in <code>tenant B</code> in Germany, you can do this by running two instances of FusionAuth. You can keep system wide configuration in sync using scripts with the client library.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2656</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2656</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 19 Mar 2021 23:17:09 GMT</pubDate></item></channel></rss>
