<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How do I use FusionAuth in my CI&#x2F;CD system?]]></title><description><![CDATA[<p dir="auto">How do I use FusionAuth in my CI/CD system?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/898/how-do-i-use-fusionauth-in-my-ci-cd-system</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 17:56:17 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/898.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Mar 2021 23:18:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How do I use FusionAuth in my CI&#x2F;CD system? on Mon, 30 Sep 2024 19:44:15 GMT]]></title><description><![CDATA[<p dir="auto">You can also use our GitHub action to easily add FusionAuth to a GitHub workflow.</p>
<p dir="auto">Here's the action: <a href="https://github.com/FusionAuth/fusionauth-github-action" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-github-action</a></p>
<p dir="auto">Here's doc about how to use it: <a href="https://fusionauth.io/docs/get-started/run-in-the-cloud/github-actions" rel="nofollow ugc">https://fusionauth.io/docs/get-started/run-in-the-cloud/github-actions</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/7529</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7529</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 30 Sep 2024 19:44:15 GMT</pubDate></item><item><title><![CDATA[Reply to How do I use FusionAuth in my CI&#x2F;CD system? on Fri, 19 Mar 2021 23:20:22 GMT]]></title><description><![CDATA[<p dir="auto">You can run FusionAuth in a docker container and spin it up using the <a href="https://fusionauth.io/docs/v1/tech/installation-guide/docker/" rel="nofollow ugc">docker install instructions</a> in your CI/CD pipeline.</p>
<p dir="auto">You may also be interested in using <a href="https://fusionauth.io/docs/v1/tech/installation-guide/kickstart/" rel="nofollow ugc">Kickstart</a>, which lets you configure every aspect of FusionAuth (except adding multiple API keys) via a simple JSON file. This ensures your integration tests run against an auth system that has been configured exactly as you expect.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2658</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2658</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 19 Mar 2021 23:20:22 GMT</pubDate></item></channel></rss>
