<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My user registrations keep disappearing]]></title><description><![CDATA[<p dir="auto">Version: 1.22.2</p>
<p dir="auto">My user registrations keep vanishing. The user shows as not registered in the UI, and an API request shows the missing registration. However, a search of the database shows the registration is there. Initially I thought this might be an issue with Elasticsearch since I have it enabled. However, after doing a successful reindex, the registration still does not reappear. If I delete the user and recreate them, the registration will last for a few weeks before disappearing again.</p>
<p dir="auto">What am I missing here?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/922/my-user-registrations-keep-disappearing</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 11:49:33 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/922.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 04 Apr 2021 18:34:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to My user registrations keep disappearing on Thu, 22 Apr 2021 00:22:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/196">@orrett</a></p>
<p dir="auto">You are welcome!  Hope it goes well!</p>
]]></description><link>https://fusionauth.io/community/forum/post/2867</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2867</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Thu, 22 Apr 2021 00:22:26 GMT</pubDate></item><item><title><![CDATA[Reply to My user registrations keep disappearing on Thu, 15 Apr 2021 16:18:29 GMT]]></title><description><![CDATA[<p dir="auto">Hey Joshua,</p>
<p dir="auto">Thank you so much for all the help. I have disabled the auto delete function for now. I believe the best way to have auto delete unverified users action enabled is to force a user to verify their email before they are allowed entrance into the app.</p>
<p dir="auto">Thankfully such a functionality is pretty easy for me to enable on the front and backend of the app.</p>
<p dir="auto">I will take a look at the articles you linked to.</p>
<p dir="auto">Thanks again,</p>
]]></description><link>https://fusionauth.io/community/forum/post/2820</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2820</guid><dc:creator><![CDATA[orrett]]></dc:creator><pubDate>Thu, 15 Apr 2021 16:18:29 GMT</pubDate></item><item><title><![CDATA[Reply to My user registrations keep disappearing on Thu, 15 Apr 2021 20:59:30 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/196">@orrett</a>,</p>
<h3>Unverified Users</h3>
<p dir="auto">You are allowed a user-specified amount of time before the delete action occurs.  One thought would be to set a longer timeline, such as say, 90 days, and have a script/chron job that runs through our APIs to track/validate/process the unverified users before they are deleted.  Or you could keep unverified users in your application and periodically run a script to capture and act on that as well.</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1618441847521-screen-shot-2021-04-14-at-5.08.33-pm-resized.png" alt="Screen Shot 2021-04-14 at 5.08.33 PM.png" class=" img-fluid img-markdown" /></p>
<h3>Docker</h3>
<p dir="auto">I would recommend reviewing our <a href="https://fusionauth.io/docs/v1/tech/installation-guide/docker/" rel="nofollow ugc">standard installation guide</a> for Docker if you have not already (sounds like you may have).  All errors are sent to STDOUT.</p>
<p dir="auto">Due to the many different ways in which one can configure Docker and specifically K8's, we do not yet have documentation on how to set up something such as a logger.  A quick google search reveals:</p>
<li><a href="https://docs.docker.com/config/containers/logging/configure/" rel="nofollow ugc">https://docs.docker.com/config/containers/logging/configure/</a></li>
<li><a href="https://docs.docker.com/config/containers/logging/" rel="nofollow ugc">https://docs.docker.com/config/containers/logging/</a></li>
<li><a href="https://docs.docker.com/config/containers/logging/dual-logging/" rel="nofollow ugc">https://docs.docker.com/config/containers/logging/dual-logging/</a></li>
<p dir="auto">These may assist you as you attempt to get up and running on Kubernetes!</p>
<p dir="auto">As a final note</p>
<li>Our docker Github/container repo can be found <a href="https://github.com/FusionAuth/fusionauth-containers" rel="nofollow ugc">here</a></li>
<li>Our Kubernetes's Github repo can be found <a href="https://github.com/FusionAuth/fusionauth-containers/tree/master/kubernetes" rel="nofollow ugc">here</a></li>
<li>Our docker installation guide <a href="https://fusionauth.io/docs/v1/tech/installation-guide/docker/" rel="nofollow ugc">here</a></li>
<p dir="auto">Both contain additional information that you might find helpful.</p>
<p dir="auto">I will let you know if I think of anything else!</p>
<p dir="auto">Thanks!<br />
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/2817</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2817</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Thu, 15 Apr 2021 20:59:30 GMT</pubDate></item><item><title><![CDATA[Reply to My user registrations keep disappearing on Tue, 13 Apr 2021 17:08:48 GMT]]></title><description><![CDATA[<p dir="auto">i am going to check if that policy is enabled. I believe I did enable it. However what I am wondering is if it would just delete the app registration but leave the user within the database?</p>
<p dir="auto">Also do you have any docs on configuring log output for the docker instance? I did see info concerning standard installations. However I am running this in docker, and soon moving it to Kubernetes</p>
]]></description><link>https://fusionauth.io/community/forum/post/2798</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2798</guid><dc:creator><![CDATA[orrett]]></dc:creator><pubDate>Tue, 13 Apr 2021 17:08:48 GMT</pubDate></item><item><title><![CDATA[Reply to My user registrations keep disappearing on Thu, 08 Apr 2021 16:12:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/196">@orrett</a>,</p>
<p dir="auto">Also, there is a policy for deleting registrations that are not verified. See <code>application &gt; registration</code></p>
<p dir="auto">If you have this enabled, it may be the source of your troubles as well.</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1617898266656-verify_registrations_app.png" alt="verify_registrations_app.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Thanks,<br />
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/2767</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2767</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Thu, 08 Apr 2021 16:12:10 GMT</pubDate></item><item><title><![CDATA[Reply to My user registrations keep disappearing on Wed, 07 Apr 2021 23:17:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/196">@orrett</a> !</p>
<p dir="auto">Thanks for the question!</p>
<p dir="auto">Hmmm, this is a tricky one to diagnose without more information.  Are you getting any errors or flags that are showing up in your logs?  Is your ElasticSearch node/cluster healthy?  Are your database and FusionAuth-app sized appropriately?</p>
<p dir="auto">The red herring may be in the cyclical nature of the failures; tracking that down might be the hard part.  But we can give it a shot!</p>
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/2763</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2763</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Wed, 07 Apr 2021 23:17:54 GMT</pubDate></item></channel></rss>
