<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can I create a tenant with the API?]]></title><description><![CDATA[<p dir="auto">Auth0 does not let you programmatically create tenants via the API. You have to log in and use their UX.</p>
<p dir="auto">Does  FusionAuth let you create a tenant programmatically?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/927/can-i-create-a-tenant-with-the-api</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 20:14:45 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/927.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 07 Apr 2021 18:51:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can I create a tenant with the API? on Wed, 07 Apr 2021 18:53:46 GMT]]></title><description><![CDATA[<p dir="auto">Yes.</p>
<p dir="auto">The only thing you can't create via the API is another API key. You can track that <a href="https://github.com/FusionAuth/fusionauth-issues/issues/887" rel="nofollow ugc">functionality on this issue</a>.</p>
<p dir="auto">See the <a href="https://fusionauth.io/docs/v1/tech/apis/tenants/" rel="nofollow ugc">tenant documentation for more</a>.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2757</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2757</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 07 Apr 2021 18:53:46 GMT</pubDate></item></channel></rss>
