<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to implement user invitation?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Since I could not find anything regarding invitation based membership I would like to know if there is an easier workaround than what I will describe here.</p>
<p dir="auto">The desired flow is that an existing member could invite a new user via email. A new user would set their personal information and password and becomes a member.</p>
<li>User A creates unverified User B on FusionAuth via api with just an email.</li>
<li>Trigger a password change email with a custom template.</li>
<li>User B opens a link and sets a new password.</li>
<li>User B logins to the application and updates personal information on the application and FusionAuth via API.</li>
<p dir="auto">Is this possible with FusionAuth or is there an easier way? Is there a chance that this <a href="https://github.com/FusionAuth/fusionauth-issues/issues/743#issuecomment-664365516" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/743#issuecomment-664365516</a> will be implemented?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://fusionauth.io/community/forum/topic/935/how-to-implement-user-invitation</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Mar 2026 13:14:37 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/935.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Apr 2021 21:38:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to implement user invitation? on Tue, 13 Apr 2021 19:52:36 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/715">@egis</a>!</p>
<p dir="auto">Welcome to the FusionAuth community!  Let me see if I can get you pointed in the right direction!</p>
<h3>API</h3>
<p dir="auto">I would suggest reviewing our Users API which allows for a flow similar to what you are describing (if I understand you correctly).</p>
<p dir="auto"><a href="https://fusionauth.io/docs/v1/tech/apis/users/#create-a-user" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/apis/users/#create-a-user</a></p>
<pre><code class="language-plain">Request Body
sendSetPasswordEmail [Boolean] OPTIONAL Defaults to false
Indicates to FusionAuth to send the User an email asking them to set their password. The Email Template that is used is configured in the System Configuration setting for Set Password Email Template.
If you set this value to true the password field is then ignored, FusionAuth will set the initial password to a securely generated random string.
If you have also enabled email verification and do not select to skip verification using the skipVerification parameter, only the setup password email will be sent to the user. Setting up the password using the email sent during this user create operation will implicitly verify the User’s email if it is not already verified.
If the SMTP email configuration is not complete, or disabled, this value is ignored.
<h3>Via UI</h3>
<p dir="auto">Once a user has been added by an admin via the UI, there is an option to send a<br />
toggle to “Send email to setup password." which would reproduce the functionality described above.</p>
<h3>Email templates</h3>
<p dir="auto">Remember to select a template in <code>Applications</code> via UI<br />
<img src="/community/forum/assets/uploads/files/1618343399613-setup-password-template.png" alt="setup-password-template.png" class=" img-fluid img-markdown" /></p>
<h3>Roadmap</h3>
<p dir="auto">Is there a chance that this <a href="https://github.com/FusionAuth/fusionauth-issues/issues/743#issuecomment-664365516" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/743#issuecomment-664365516</a> will be implemented?</p>
<p dir="auto">While this issue is documented, it not on our short-term road map at this time.</p>
<p dir="auto">Please review our <a href="https://fusionauth.io/docs/v1/tech/core-concepts/roadmap/#overview" rel="nofollow ugc">roadmap guidelines</a></p>
<p dir="auto">I hope this helps on your way!</p>
<p dir="auto">Thanks,<br />
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/2802</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2802</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Tue, 13 Apr 2021 19:52:36 GMT</pubDate></item></channel></rss>
