<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unable to send email via JavaMailPrime Messaging Exception]]></title><description><![CDATA[<p dir="auto">whenever I try to send test mail I am getting the error which is <strong>"Unable to send email via JavaMailPrime Messaging Exception"</strong><img src="/community/forum/assets/uploads/files/1618554798550-screenshot-from-2021-04-16-12-00-55.png" alt="Screenshot from 2021-04-16 12-00-55.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fusionauth.io/community/forum/topic/952/unable-to-send-email-via-javamailprime-messaging-exception</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Nov 2026 01:01:09 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/952.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 16 Apr 2021 06:33:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unable to send email via JavaMailPrime Messaging Exception on Tue, 09 Apr 2024 16:03:02 GMT]]></title><description><![CDATA[<p dir="auto">I had the same issue with SMTP and how to configure it. I can confirm that most likely it is an issue with how you have configured your SMTP and FusionAuth.</p>
<p dir="auto">BTW I have created <a href="https://github.com/kasir-barati/you-say" rel="nofollow ugc">this</a> monorepo which utilizes FusionAuth, Docker, <a href="https://github.com/sj26/mailcatcher" rel="nofollow ugc">mailcatcher</a>, NestJS, and NextJS. Check how I wrote <code>fusionauth.docker-compose.yml</code> and how terraform is configuring FusionAuth. I also jot down here and there some infos about them, so if you like you can definitely read <code>README.md</code> files.</p>
<p dir="auto"><strong>I also appreciate it if you give it a star on GitHub.</strong></p>
]]></description><link>https://fusionauth.io/community/forum/post/7165</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7165</guid><dc:creator><![CDATA[kasir-barati]]></dc:creator><pubDate>Tue, 09 Apr 2024 16:03:02 GMT</pubDate></item><item><title><![CDATA[Reply to Unable to send email via JavaMailPrime Messaging Exception on Tue, 20 Apr 2021 22:37:23 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/704">@nileshnandaniya135</a>!</p>
<p dir="auto">You may want to review your SMTP settings, as this could indicate something was not set up correctly (prior to the test).  Do you have any additional errors or logs that we can review with you?</p>
<p dir="auto">Additionally, I would encourage you to review our documentation regarding setting up an SMTP service.</p>
<li><a href="https://fusionauth.io/docs/v1/tech/email-templates/configure-email/" rel="nofollow ugc">Configure</a></li>
<li><a href="https://fusionauth.io/docs/v1/tech/email-templates/" rel="nofollow ugc">Email Overview - with debug steps</a></li>
<li><a href="https://fusionauth.io/docs/v1/tech/troubleshooting/#smtp-logging" rel="nofollow ugc">Enabling Verbose Logging</a></li>
<li><a href="https://fusionauth.io/docs/v1/tech/email-templates/email-templates/" rel="nofollow ugc">Email Templates</a></li>
<p dir="auto">Thanks,<br />
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/2856</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2856</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Tue, 20 Apr 2021 22:37:23 GMT</pubDate></item></channel></rss>
