Unsolved Theme templates do not reflect updates after edit and save
Does anyone have any guesses as to why theme template changes are not showing up in our app? After editing our "Verify Registration" template and saving, the old template is still served when we test.
I've checked that it is the correct applicationId and tenantId, as well as the correct theme for the application (I've also tried editing the tenant's default theme to the same result).
Any insight as to why this would happen, or suggestions on how to debug? Thanks in advance!
Hmmm. That's no good!
What version of FusionAuth are you running?
What changes are you making? Have you tried making different changes?
There's also often some confusion between verify registration and verify email, so are you sure you are walking through the correct workflow?
