    Installation Problem
    14.0k
    • M
      michael.collis
      Good Afternoon All,
      I am trying to install FusionAuth on windows server 2012 R2, I have used the powershell command in the download section under Windows. When i run the command i get the following error
      ModuleType Version Name ExportedCommands
      Script 0.0 FusionAuth {Install-FusionAuth, install}
      Invoke-WebRequest : The underlying connection was closed: An unexpected error occurred on a send.
      At line:55 char:20
      • ... $VERSION = Invoke-WebRequest -UseBasicParsing -Uri https://metrics.f ...
        • CategoryInfo : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-WebRequest], WebExc
          eption
        • FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeWebRequestCommand
      Has anyone seen this issue before, Could anyone help me please
      Thanks
        Hmmm. I haven't seen that error before.
        Can you confirm you can download the zip file directly? https://fusionauth.io/direct-download
        That would rule out any network connectivity issues.
        • M
          michael.collis
          Hi,
          Yes i can download the files manually from the website. I'm unsure how to install this when i have them manually
          • M
            michael.collis
            I have unzipped the files and added them into C:\Folder\ an ran startup rom BIN I got to creating the database i can see in the CLI that it is creating the database but i get the follow error once the database has been created
            500 Internal Server Error
            An internal error occurred. FusionAuth should have captured a stack trace in the log. If you have a licensed edition, contact support using the form under the "Get Support" menu item. Otherwise, check your logs to see what the error might be.
              What do the logs say?
              • M
                michael.collis
                I can't see any logs in the logs folder it says this folder is empty
                  Here's a relevant question:
                  https://fusionauth.io/community/forum/topic/154/where-are-my-log-files
                  So if you are starting FusionAuth on Windows, you want to cut and paste the lines in the cmd window, which are the relevant log files.
                  • M
                    michael.collis
                    Hi,
                    I managed to get a snapshot of the error i'm not sure if this is any good
                      Hmmm. Hard to tell from here. Can you cut and paste more of the logfile?
                      • M
                        michael.collis
                        Hi,
                        Its hard to get all of the Export logs but i have getting what i can
                          at org.mybatis.guice.MyBatisModule.bindDataSourceProviderType(MyBatisModule.ja
                        va:289) (via modules: io.fusionauth.app.guice.FusionAuthModule -> com.google.inj
                        ect.util.Modules$OverrideModule -> io.fusionauth.api.guice.APIModule -> io.fusio
                        nauth.api.domain.guice.MyBatisModule)
                          while locating javax.sql.DataSource
                            for field at org.mybatis.guice.environment.EnvironmentProvider.dataSource(En
                        vironmentProvider.java:52)
                          at org.mybatis.guice.environment.EnvironmentProvider.class(EnvironmentProvider
                        .java:27)
                          while locating org.mybatis.guice.environment.EnvironmentProvider
                          at org.mybatis.guice.MyBatisModule.internalConfigure(MyBatisModule.java:110) (
                        via modules: io.fusionauth.app.guice.FusionAuthModule -> io.fusionauth.api.migra
                        tion.guice.MigrationModule)
                          while locating org.apache.ibatis.mapping.Environment
                            for the 1st parameter of org.mybatis.guice.configuration.ConfigurationProvid
                        er.<init>(ConfigurationProvider.java:109)
                          at org.mybatis.guice.configuration.ConfigurationProvider.class(ConfigurationPr
                        ovider.java:39)
                          while locating org.mybatis.guice.configuration.ConfigurationProvider
                          at org.mybatis.guice.MyBatisModule.internalConfigure(MyBatisModule.java:113) (
                          while locating org.apache.ibatis.session.Configuration
                            for the 1st parameter of org.mybatis.guice.session.SqlSessionFactoryProvider
                        .createNewSqlSessionFactory(SqlSessionFactoryProvider.java:59)
                          at org.mybatis.guice.session.SqlSessionFactoryProvider.class(SqlSessionFactory
                        Provider.java:26)
                          while locating org.mybatis.guice.session.SqlSessionFactoryProvider
                          while locating org.apache.ibatis.session.SqlSessionFactory
                            for the 1st parameter of org.mybatis.guice.session.SqlSessionManagerProvider
                        .createNewSqlSessionManager(SqlSessionManagerProvider.java:49)
                          at org.mybatis.guice.session.SqlSessionManagerProvider.class(SqlSessionManager
                        Provider.java:24)
                          while locating org.mybatis.guice.session.SqlSessionManagerProvider
                          at org.mybatis.guice.AbstractMyBatisModule.configure(AbstractMyBatisModule.jav
                        a:59) (via modules: io.fusionauth.app.guice.FusionAuthModule -> io.fusionauth.ap
                        i.migration.guice.MigrationModule)
                          while locating org.apache.ibatis.session.SqlSessionManager
                            for field at org.mybatis.guice.mappers.MapperProvider.sqlSessionManager(Mapp
                        erProvider.java:37)
                          while locating org.mybatis.guice.mappers.MapperProvider
                          at com.google.inject.util.Providers$GuicifiedProviderWithDependencies.initiali
                        ze(Providers.java:154)
                          at org.mybatis.guice.AbstractMyBatisModule.bindMapper(AbstractMyBatisModule.ja
                        va:96) (via modules: io.fusionauth.app.guice.FusionAuthModule -> io.fusionauth.a
                        pi.migration.guice.MigrationModule)
                        38) null returned by binding at org.mybatis.guice.MyBatisModule.bindDataSourcePr
                        oviderType(MyBatisModule.java:289) (via modules: io.fusionauth.app.guice.FusionA
                        uthModule -> com.google.inject.util.Modules$OverrideModule -> io.fusionauth.api.
                        guice.APIModule -> io.fusionauth.api.domain.guice.MyBatisModule)
                         but org.mybatis.guice.environment.EnvironmentProvider.dataSource(EnvironmentPro
                        vider.java:52) is not @Nullable
                          while locating com.inversoft.jdbc.hikari.DataSourceProvider
                        .java:27)
                        ovider.java:39)
                        Provider.java:26)
                        Provider.java:24)
                            for field at org.mybatis.guice.transactional.TransactionalMethodInterceptor.
                        sqlSessionManager(TransactionalMethodInterceptor.java:56)
                          at org.mybatis.guice.AbstractMyBatisModule.bindTransactionInterceptors(Abstrac
                        tMyBatisModule.java:79) (via modules: io.fusionauth.app.guice.FusionAuthModule -
                        > com.google.inject.util.Modules$OverrideModule -> io.fusionauth.api.guice.APIMo
                        39) null returned by binding at org.mybatis.guice.MyBatisModule.bindDataSourcePr
                        .java:27)
                        ovider.java:39)
                        Provider.java:26)
                        Provider.java:24)
                        > com.google.inject.util.Modules$OverrideModule -> io.fusionauth.app.guice.Fusio
                        nAuthAPIAuthenticationModule)
                        40) null returned by binding at org.mybatis.guice.MyBatisModule.bindDataSourcePr
                        .java:27)
                        ovider.java:39)
                        Provider.java:26)
                        Provider.java:24)
                        > com.google.inject.util.Modules$OverrideModule -> com.inversoft.authentication.
                        api.guice.APIAuthenticationModule)
                        41) null returned by binding at org.mybatis.guice.MyBatisModule.bindDataSourcePr
                        .java:27)
                        ovider.java:39)
                        Provider.java:26)
                        Provider.java:24)
                        > io.fusionauth.api.migration.guice.MigrationModule)
                        41 errors
                                at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist
                        (Errors.java:554)
                                at com.google.inject.internal.InternalInjectorCreator.injectDynamically(
                        InternalInjectorCreator.java:180)
                                at com.google.inject.internal.InternalInjectorCreator.build(InternalInje
                        ctorCreator.java:111)
                                at com.google.inject.Guice.createInjector(Guice.java:87)
                                at com.google.inject.Guice.createInjector(Guice.java:69)
                                at com.google.inject.Guice.createInjector(Guice.java:59)
                                at org.primeframework.mvc.guice.GuiceBootstrap.initialize(GuiceBootstrap
                        .java:58)
                                at com.inversoft.maintenance.MaintenanceModeService.done(MaintenanceMode
                        Service.java:67)
                                at com.inversoft.maintenance.MaintenanceModeThreadSafeHelper.areWeDoneYe
                        t(MaintenanceModeThreadSafeHelper.java:59)
                                at com.inversoft.maintenance.MaintenanceModePoller.lambda$new$1(Maintena
                        nceModePoller.java:46)
                                at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executo
                        rs.java:515)
                                at java.base/java.util.concurrent.FutureTask.runAndReset(FutureTask.java
                        :305)
                                at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledF
                        utureTask.run(ScheduledThreadPoolExecutor.java:305)
                                at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoo
                        lExecutor.java:1130)
                                at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPo
                        olExecutor.java:630)
                                at java.base/java.lang.Thread.run(Thread.java:832)
                        Thanks
                          Hmmm. Can you scroll or anything? What we're really after is the first set of exceptions at the top of the log, which should give us a starting point to troubleshoot.
                          • M
                            michael.collis
                            Hi,
                            I tried to get as much as possible on logs and this is all i can get
                            NOTE: Picked up JDK_JAVA_OPTIONS:  --add-opens=java.base/java.lang=ALL-UNNAMED -
                            -add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.rmi/sun.rmi.transport=
                            ALL-UNNAMED
                            24-Jul-2020 15:37:49.580 WARNING [main] org.apache.catalina.startup.SetAllProper
                            tiesRule.begin [SetAllPropertiesRule]{Server/Service/Connector} Setting property
                             'maxHttpHeaderSize' to '${fusionauth.http.max.header-size}' did not find a matc
                            hing property.
                            24-Jul-2020 15:37:49.674 WARNING [main] org.apache.catalina.startup.SetAllProper
                            hing property.
                            24-Jul-2020 15:37:49.940 INFO [main] org.apache.catalina.core.AprLifecycleListen
                            er.lifecycleEvent The APR based Apache Tomcat Native library which allows optima
                            l performance in production environments was not found on the java.library.path:
                             [C:\MFA\java\jdk-14.0.1+7\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Wi
                            ndows;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System3
                            2\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Skype\Phone\;C:\Program Files\M
                            icrosoft\Web Platform Installer\;C:\Program Files\MySQL\MySQL Server 5.5\bin;.]
                            24-Jul-2020 15:37:50.971 INFO [main] org.apache.coyote.AbstractProtocol.init Ini
                            tializing ProtocolHandler ["http-nio-9011"]
                            24-Jul-2020 15:37:51.127 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.
                            getSharedSelector Using a shared selector for servlet write/read
                            24-Jul-2020 15:37:51.174 INFO [main] org.apache.coyote.AbstractProtocol.init Ini
                            tializing ProtocolHandler ["https-jsse-nio-9013"]
                            24-Jul-2020 15:37:51.924 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.
                            24-Jul-2020 15:37:51.940 INFO [main] org.apache.coyote.AbstractProtocol.init Ini
                            tializing ProtocolHandler ["ajp-nio-127.0.0.1-9019"]
                            24-Jul-2020 15:37:51.940 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.
                            24-Jul-2020 15:37:51.955 INFO [main] org.apache.catalina.startup.Catalina.load I
                            nitialization processed in 2903 ms
                            24-Jul-2020 15:37:51.971 INFO [main] org.apache.catalina.core.StandardService.st
                            artInternal Starting service [Catalina]
                            24-Jul-2020 15:37:51.971 INFO [main] org.apache.catalina.core.StandardEngine.sta
                            rtInternal Starting Servlet Engine: Apache Tomcat/8.5.53
                            Jul 24, 2020 3:37:57 PM org.apache.jasper.servlet.TldScanner scanJars
                            INFO: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug
                            logging for this logger for a complete list of JARs that were scanned but no TLD
                            s were found in them. Skipping unneeded JARs during scanning can improve startup
                             time and JSP compilation time.
                            Jul 24, 2020 3:37:59.065 pm INFO  io.fusionauth.api.configuration.PropertiesFile
                            FusionAuthConfiguration - Loading FusionAuth configuration file [C:\MFA\config\f
                            usionauth.properties]
                            Jul 24, 2020 3:37:59.174 pm INFO  io.fusionauth.api.configuration.PropertiesFile
                            FusionAuthConfiguration - Dynamically set property [fusionauth-app.url] set to [
                            http://10.250.118.35:9011]
                            Jul 24, 2020 3:37:59.190 pm INFO  io.fusionauth.api.configuration.PropertiesFile
                            FusionAuthConfiguration - Set Max HTTP header size to [8192].
                            Jul 24, 2020 3:38:01.549 pm INFO  io.fusionauth.api.configuration.PropertiesFile
                            Jul 24, 2020 3:38:01.627 pm INFO  io.fusionauth.api.configuration.PropertiesFile
                            Jul 24, 2020 3:38:01.690 pm INFO  io.fusionauth.api.configuration.PropertiesFile
                            Jul 24, 2020 3:38:01.768 pm INFO  io.fusionauth.api.configuration.PropertiesFile
                            Jul 24, 2020 3:38:02.955 pm INFO  io.fusionauth.app.maintenance.FusionAuthMainte
                            nanceModeWorkflow - Determine database status : DOWN
                            Jul 24, 2020 3:38:02.955 pm INFO  org.primeframework.mvc.servlet.PrimeServletCon
                            textListener - Initializing Prime
                            Jul 24, 2020 3:38:02.955 pm INFO  io.fusionauth.app.maintenance.guice.FusionAuth
                            MaintenanceModeModule -
                            --------------------------------------- Entering Maintenance Mode --------------
                            Jul 24, 2020 3:38:03.205 pm INFO  io.fusionauth.api.configuration.PropertiesFile
                            Jul 24, 2020 3:38:03.283 pm INFO  io.fusionauth.api.configuration.PropertiesFile
                            Jul 24, 2020 3:38:03.283 pm INFO  com.inversoft.maintenance.MaintenanceModePolle
                            r - Poller started to Wait for configuration to be completed.
                            24-Jul-2020 15:38:03.393 INFO [main] org.apache.coyote.AbstractProtocol.start St
                            arting ProtocolHandler ["http-nio-9011"]
                            24-Jul-2020 15:38:03.424 INFO [main] org.apache.coyote.AbstractProtocol.start St
                            arting ProtocolHandler ["https-jsse-nio-9013"]
                            24-Jul-2020 15:38:03.440 INFO [main] org.apache.coyote.AbstractProtocol.start St
                            arting ProtocolHandler ["ajp-nio-127.0.0.1-9019"]
                            24-Jul-2020 15:38:03.440 INFO [main] org.apache.catalina.startup.Catalina.start
                            Server startup in 11490 ms
                              applications_id            BINARY(16) NOT NULL,
                              clean_speak_application_id BINARY(16) NOT NULL,
                              CONSTRAINT clean_speak_applications_fk_1 FOREIGN KEY (applications_id) REFEREN
                            CES applications(id),
                              CONSTRAINT clean_speak_applications_uk_1 UNIQUE (applications_id, clean_speak_
                            application_id)
                              ENGINE = innodb
                              CHARACTER SET utf8mb4
                              COLLATE utf8mb4_bin;
                            CREATE TABLE application_roles (
                              description         VARCHAR(255) NULL,
                              insert_instant      BIGINT       NOT NULL,
                              is_default          BIT(1)       NOT NULL,
                              is_super_role       BIT(1)       NOT NULL,
                              last_update_instant BIGINT       NOT NULL,
                              name                VARCHAR(191) NOT NULL,
                              PRIMARY KEY (id),
                              CONSTRAINT application_roles_uk_1 UNIQUE (name, applications_id),
                              CONSTRAINT application_roles_fk_1 FOREIGN KEY (applications_id) REFERENCES app
                            lications(id)
                              ENGINE = innodb
                            CREATE TABLE `groups` (
                              data                MEDIUMTEXT   NULL,
                              tenants_id          BINARY(16)   NOT NULL,
                              PRIMARY KEY (id),
                              CONSTRAINT groups_uk_1 UNIQUE (name, tenants_id),
                              CONSTRAINT groups_fk_1 FOREIGN KEY (tenants_id) REFERENCES tenants(id)
                              ENGINE = innodb
                            CREATE TABLE group_application_roles (
                              application_roles_id BINARY(16) NOT NULL,
                              groups_id            BINARY(16) NOT NULL,
                              CONSTRAINT group_application_roles_uk_1 UNIQUE (groups_id, application_roles_i
                            d),
                              CONSTRAINT group_application_roles_fk_1 FOREIGN KEY (groups_id) REFERENCES `gr
                            oups`(id),
                              CONSTRAINT group_application_roles_fk_2 FOREIGN KEY (application_roles_id) REF
                            ERENCES application_roles(id)
                              ENGINE = innodb
                            CREATE TABLE webhooks (
                              connect_timeout              INTEGER      NOT NULL,
                              data                         TEXT         NULL,
                              global                       BIT(1)       NOT NULL,
                              headers                      TEXT         NULL,
                              http_authentication_username VARCHAR(255) NULL,
                              http_authentication_password VARCHAR(255) NULL,
                              read_timeout                 INTEGER      NOT NULL,
                              ssl_certificate              TEXT         NULL,
                              url                          TEXT         NOT NULL,
                              PRIMARY KEY (id)
                              ENGINE = innodb
                            CREATE TABLE webhooks_applications (
                              webhooks_id     BINARY(16) NOT NULL,
                              PRIMARY KEY (webhooks_id, applications_id),
                              CONSTRAINT webhooks_applications_fk_1 FOREIGN KEY (webhooks_id) REFERENCES web
                            hooks(id),
                              CONSTRAINT webhooks_applications_fk_2 FOREIGN KEY (applications_id) REFERENCES
                             applications(id)
                              ENGINE = innodb
                            -- External Ids
                            CREATE TABLE external_identifiers (
                              id              VARCHAR(191) NOT NULL,
                              applications_id BINARY(16)   NULL,
                              data            TEXT         NULL,
                              type            SMALLINT     NOT NULL,
                              users_id        BINARY(16)   NULL,
                              PRIMARY KEY (id),
                              CONSTRAINT external_identifiers_fk_1 FOREIGN KEY (users_id) REFERENCES users(i
                            d),
                              CONSTRAINT external_identifiers_fk_2 FOREIGN KEY (applications_id) REFERENCES
                            applications(id),
                              CONSTRAINT external_identifiers_fk_3 FOREIGN KEY (tenants_id) REFERENCES tenan
                            ts(id)
                              ENGINE = innodb
                            CREATE INDEX external_identifiers_i_1 ON external_identifiers(tenants_id, type,
                            insert_instant);
                            CREATE INDEX external_identifiers_i_2 ON external_identifiers(type, users_id, ap
                            plications_id);
                            CREATE TABLE user_registrations (
                              authentication_token VARCHAR(255) NULL,
                              clean_speak_id       BINARY(16)   NULL,
                              last_login_instant   BIGINT       NULL,
                              timezone             VARCHAR(255) NULL,
                              username             VARCHAR(191) NULL,
                              username_status      SMALLINT     NOT NULL,
                              users_id             BINARY(16)   NOT NULL,
                              verified             BIT(1)       NOT NULL,
                              PRIMARY KEY (id),
                              CONSTRAINT user_registrations_uk_1 UNIQUE KEY (applications_id, users_id),
                              CONSTRAINT user_registrations_fk_1 FOREIGN KEY (applications_id) REFERENCES ap
                            plications(id),
                              CONSTRAINT user_registrations_fk_2 FOREIGN KEY (users_id) REFERENCES users(id)
                              ENGINE = innodb
                            CREATE INDEX user_registrations_i_1 ON user_registrations(clean_speak_id);
                            # No need to create an explicit index on applications_id because it is the first
                             key in the UNIQUE constraint
                            CREATE INDEX user_registrations_i_2 ON user_registrations(users_id);
                            CREATE TABLE user_registrations_application_roles (
                              user_registrations_id BINARY(16) NOT NULL,
                              CONSTRAINT user_registrations_application_roles_uk_1 UNIQUE (user_registration
                            s_id, application_roles_id),
                              CONSTRAINT user_registrations_application_roles_fk_1 FOREIGN KEY (user_registr
                            ations_id) REFERENCES user_registrations(id),
                              CONSTRAINT user_registrations_application_roles_fk_2 FOREIGN KEY (application_
                            roles_id) REFERENCES application_roles(id)
                              ENGINE = innodb
                            CREATE TABLE families (
                              family_id           BINARY(16) NOT NULL,
                              owner               BIT(1)     NOT NULL,
                              role                SMALLINT   NOT NULL,
                              PRIMARY KEY (family_id, users_id),
                              CONSTRAINT families_fk_1 FOREIGN KEY (users_id) REFERENCES users(id)
                              ENGINE = innodb
                            CREATE INDEX families_i_1 ON families(users_id);
                            CREATE TABLE group_members (
                              PRIMARY KEY (id),
                              CONSTRAINT group_members_uk_1 UNIQUE (groups_id, users_id),
                              CONSTRAINT group_members_fk_1 FOREIGN KEY (users_id) REFERENCES users(id),
                              CONSTRAINT group_members_fk_2 FOREIGN KEY (groups_id) REFERENCES `groups`(id)
                              ENGINE = innodb
                            CREATE INDEX group_members_i_1 ON group_members(users_id);
                            # No need to create an explicit index on groups_id because it is the first key i
                            CREATE TABLE user_action_logs (
                              actioner_users_id  BINARY(16)   NULL,
                              actionee_users_id  BINARY(16)   NOT NULL,
                              comment            TEXT         NULL,
                              email_user_on_end  BIT(1)       NOT NULL,
                              end_event_sent     BIT(1)       NULL,
                              expiry             BIGINT       NULL,
                              history            TEXT         NULL,
                              localized_name     VARCHAR(191) NULL,
                              localized_option   VARCHAR(255) NULL,
                              localized_reason   VARCHAR(255) NULL,
                              notify_user_on_end BIT(1)       NOT NULL,
                              option_name        VARCHAR(255) NULL,
                              reason_code        VARCHAR(255) NULL,
                              user_actions_id    BINARY(16)   NOT NULL,
                              PRIMARY KEY (id),
                              CONSTRAINT user_action_logs_fk_1 FOREIGN KEY (actioner_users_id) REFERENCES us
                            ers(id),
                              CONSTRAINT user_action_logs_fk_2 FOREIGN KEY (actionee_users_id) REFERENCES us
                            ers(id),
                              CONSTRAINT user_action_logs_fk_3 FOREIGN KEY (user_actions_id) REFERENCES user
                            _actions(id)
                              ENGINE = innodb
                            CREATE INDEX user_action_logs_i_1 ON user_action_logs(insert_instant);
                            CREATE INDEX user_action_logs_i_2 ON user_action_logs(expiry, end_event_sent);
                            CREATE TABLE user_action_logs_applications (
                              user_action_logs_id BINARY(16) NOT NULL,
                              CONSTRAINT user_action_logs_applications_fk_1 FOREIGN KEY (applications_id) RE
                            FERENCES applications(id)
                                ON DELETE CASCADE,
                              CONSTRAINT user_action_logs_applications_fk_2 FOREIGN KEY (user_action_logs_id
                            ) REFERENCES user_action_logs(id)
                                ON DELETE CASCADE
                              ENGINE = innodb
                            CREATE TABLE user_comments (
                              comment        TEXT       NULL,
                              commenter_id   BINARY(16) NOT NULL,
                              PRIMARY KEY (id),
                              CONSTRAINT user_comments_fk_1 FOREIGN KEY (users_id) REFERENCES users(id),
                              CONSTRAINT user_comments_fk_2 FOREIGN KEY (commenter_id) REFERENCES users(id)
                              ENGINE = innodb
                            CREATE INDEX user_comments_i_1 ON user_comments(insert_instant);
                            CREATE INDEX user_comments_i_2 ON user_comments(users_id);
                            CREATE INDEX user_comments_i_3 ON user_comments(commenter_id);
                            CREATE TABLE authentication_keys (
                              permissions         TEXT         NULL,
                              meta_data           TEXT         NULL,
                              tenants_id          BINARY(16)   NULL,
                              PRIMARY KEY (id),
                              CONSTRAINT authentication_keys_fk_1 FOREIGN KEY (tenants_id) REFERENCES tenant
                            s(id)
                              ENGINE = innodb
                            CREATE TABLE system_configuration (
                              data                LONGTEXT     NOT NULL,
                              report_timezone     VARCHAR(255) NOT NULL
                              ENGINE = innodb
                            CREATE TABLE raw_logins (
                              ip_address      VARCHAR(255) NULL,
                              CONSTRAINT raw_logins_fk_1 FOREIGN KEY (applications_id) REFERENCES applicatio
                            ns(id),
                              CONSTRAINT raw_logins_fk_2 FOREIGN KEY (users_id) REFERENCES users(id)
                              ENGINE = innodb
                            CREATE INDEX raw_logins_i_1 ON raw_logins(instant);
                            CREATE INDEX raw_logins_i_2 ON raw_logins(users_id, instant);
                            CREATE TABLE hourly_logins (
                            .java:27)
                            ovider.java:39)
                            Provider.java:26)
                            Provider.java:24)
                            erProvider.java:37)
                            .java:27)
                            ovider.java:39)
                            Provider.java:26)
                            Provider.java:24)
                            .java:27)
                            ovider.java:39)
                            Provider.java:26)
                            Provider.java:24)
                            .java:27)
                            ovider.java:39)
                            Provider.java:26)
                            Provider.java:24)
                            .java:27)
                            • M
                              michael.collis
                              ovider.java:39)
                              Provider.java:26)
                              Provider.java:24)
                              41 errors
                              (Errors.java:554)
                              .java:58)
                              Service.java:67)
                              rs.java:515)
                              :305)
                                Ah. It looks like you are using mysql. What is your character set? Here's how to find it: https://stackoverflow.com/questions/1049728/how-do-i-see-what-character-set-a-mysql-database-table-column-is
                                If it is not utf8mb4, FusionAuth may function incorrectly. See https://fusionauth.io/community/forum/topic/152/what-happens-if-i-turn-off-database-mysql-enforce-utf8mb4 for more details.
                                Alternatives:
                                • set up your database with utf8mb4. I'd google for how to do that.
                                • turn off the utf8mb4 check, as documented here: https://fusionauth.io/docs/v1/tech/reference/configuration#properties (basically set database.mysql.enforce-utf8mb4 in your fusionauth.properties to false).
                                You might do the second option first to ensure that solves your issue. Can you try that and see if that is the problem?
                                • M
                                  michael.collis
                                  Hi,
                                  Thank you for this i have managed to get past the issue with the database i changed to to postgres SQL and it worked fine, I'm just to figure out if i can ass Exchange 2016 to this application so users are made to get a Auth code before they can logon to exchange.
                                  • A
                                    admin a
                                    Thank you for taking the time to offer these solutions. Your support has made a challenging situation much more manageable.
