    Default tenant id in client library
    client-library default tenant
    2.6k
      I am trying to create tenants using the Java API and want to use the default tenant as a baseline.
      Is there a way to get the default tenant ID from the client library or do I have to retrieve it from the admin UI manually?
        You will need to obtain the default tenantId from the UI.
        If you are using kickstart, you have the option to set the default tenantId so that it is predictable.
