    Where would I change the "X-Frame-Options" header when running FusionAuth from a RPM package
    1.9k
    • joshuaJ
      joshua
      I set it in nginx, that is running in front of FA, but FA seems to overwrite/ force the header.
      • joshuaJ
        joshua
        Hi,
        I might need some more details, but one place to start is reviewing the setting panel for CORS.
        There is also a recent related post about X-Frame-Headers here.
        Any more details about what you are trying to accomplish might helpful.
        Josh
        • F
          felix
          Setting the "Allowed origins" in the Application settings did the trick.
