    FusionAuth SDK searchuser method problem
    • A
      adrian.wild
      I found out the problem. I have over 8000 users in my DB. I wanted to take them all by
      $arrayOfParameters = array(
          'search' => array(
              'queryString' => '*',
              'numberOfResults' => 1000,
              'startRow' => 0, // Then 1000...2000...3000
              'accurateTotal' => true
      $client->searchUsersByQuery($arrayOfParameters);
      And when i go with this logic of increasing the startRow value then i see:
      int(26)
      int(787)
      int(353)
      int(806)
      int(596)
      int(435)
      int(997)
      int(23)
      int(5023)
      This is call by call (in foreach) count result how many users i get (I always increase startRow by 1000). So why on the end i get different numbers of users? If once is possible to get 1000 why not always?
      Does anyone had this problem before?
        Hiya @adrian-wild
        To confirm, you are using the elastic search search engine?
        And the numbers in the list you provided are the number of results you get?
