    Advanced Threat Detection never turns on for me
    reactor paid edition oom
    5.9k
      I am running 1.30 and advanced threat detection (on the reactor page) is always stuck in "Pending" state.
      When I look at my logs, they have error messages like:
      fusionauth_1  | Caused by: java.lang.OutOfMemoryError: Java heap space
      fusionauth_1  | 2021-08-20 12:28:36.995 AM ERROR com.inversoft.scheduler.LogAndRetainFailureHandler - The scheduled service [class io.fusionauth.api.service.cache.MaxMindDatabaseLoader] failed but will be re-run.
      fusionauth_1  | java.lang.Exception: java.lang.OutOfMemoryError: Java heap space
      fusionauth_1  |         at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
      fusionauth_1  |         at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
      fusionauth_1  |         at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
      fusionauth_1  |         at java.base/java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:500)
      fusionauth_1  |         at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:481)
      fusionauth_1  |         at org.mybatis.guice.transactional.TransactionalMethodInterceptor.convertThrowableIfN
      What is going on?
        If you are running Advanced Threat Detection, you need at least 2GB of memory for each FusionAuth node.
        Here's the system requirements: https://fusionauth.io/docs/v1/tech/installation-guide/system-requirements/ which document the 2GB requirement when using this feature.
        • M
          markvanber
          This post is deleted!
          • H
            henryadams941
