    Unable to connect maintanance mode with Postgresql
    • S
      sharma
      Unable to connect maintanance mode with Postgresql iam able to connect to database and port is open, firewall is down OS redhat 8.4
      S 1 Reply Last reply Reply Quote 0
      • S
        sharma @sharma
        @sharma Unable to connect to your database using either the superuser username and password or ordinary username and password you provided. Please verify your connection information. If it is correct, make sure the database is running before continuing.
