    Fusion auth login error - react-native
    5.8k
    • E
      erick
      When I changed the compileSdkVersion and targetSdkVersion from 29 to 30 which is now required for google play, the login process does not work. When I try to login, fusion auth shows that error, attach the image below.
      • joshuaJ
        joshua
        @erick
        I built this out last week and was able to have everything run correctly on iOS simulator.
        Here are my Gradle files (excerpted)
        buildscript {
            ext {
                buildToolsVersion = "30.0.2"
                minSdkVersion = 21
                compileSdkVersion = 30
                targetSdkVersion = 30
                ndkVersion = "21.4.7075529"
        Are you able to try this on a macOS? It may not be necessary, but would be good to know if the problem is limited to Android or not. I can try building with the android simulator today or tommorrow and let you know if I run into any difficulty.
        Josh
        E 1 Reply Last reply Reply Quote 0
        • E
          erick @joshua
          @joshua said in Fusion auth login error - react-native:
          "30.0.2"
          Hello, thanks for your reply.
          This problem only occurred on android and I just copied your gradle configuration and I get the same error. I use react native 0.60.5
          I attach images:
          Captura de Pantalla 2021-10-26 a la(s) 10.08.36 a. m..png Captura de Pantalla 2021-10-26 a la(s) 10.08.24 a. m..png
          • joshuaJ
            joshua @erick
            @erick
            Apologies for the delay. I was not able to test the andriod portion of this very well on my Mac. Is this still an open issue for you?
            Josh
